LX200v50 EVB Resetting
I’m using 7550 AVitar software to configure my LX200v50 with EVB for PLC communication but after writing our pib file the module restarts to initialize the new configuration file, when the module is powered on again it just resets to its initial state and we can make sure of that by reading the pib file written on the module again and it just shows that all the configuration has reset to its initial values.
so I switched to use open-plc-utils then i get the error message of “bootloader must be running operation canceled” when i try to make anything to the module.
I have contacted [email protected] but I got no answer.
Can someone help me with this issue maybe I need a firmware update, I already tried to search for that but couldn’t find any.
Did anyone contacted you or you find any solution ??
