I am trying to use an SPS30 with a custom-built RAK3172 board running on RUI3. But I am not able to read SPS30 on the i2c port. I can read the rest of the i2c devices, like DS3231, SCD30, and many more devices except SPS30. I tested the sensor with an ESP32, and it works fine with it. Below is the code which I used for scanning.
#include <Wire.h>
void setup()
Wire.begin();
while (!Serial); // Leonardo: wait for serial monitor
Serial.println("\nI2C Scanner");
void loop()
byte error, address;
int nDevices;
Serial.println("Scanning...");
nDevices = 0;
for(address = 1; address < 127; address++ )
// The i2c_scanner uses the return value of
// the Write.endTransmisstion to see if
// a device did acknowledge to the address.
Wire.beginTransmission(address);
error = Wire.endTransmission();
if (error == 0)
Serial.print("I2C device found at address 0x");
if (address<16)
Serial.print("0");
Serial.print(address,HEX);
Serial.println(" !");
nDevices++;
else if (error==4)
Serial.print("Unknown error at address 0x");
if (address<16)
Serial.print("0");
Serial.println(address,HEX);
if (nDevices == 0)
Serial.println("No I2C devices found\n");
else
Serial.println("done\n");
delay(5000); // wait 5 seconds for next scan
The same thing I am able to read the device in Mbed OS when I scan for i2c devices. (SPS30 address is 0x69)
