If I try to upload any code from Arduino to RAK1300, I get this :
Do I miss something ?
there’s more to the error than you have shown … any chance of showing the whole output?
@Batto
Could be related to a problem that we still couldn’t fix.
The RP2040 BSP calls a batch file at the end of the installation to get some drivers installed. This requires admin rights on a Windows PC and it fails.
You can fix it by going into the installation directory of the BSP. On my computer the path is
C:\Users\Creatronic\AppData\Local\Arduino15\packages\rakwireless\hardware\mbed_rp2040\0.0.6
Inside that folder is a file called post_install.bat. Open a command prompt or the power shell in this folder and run post_install.bat manually. It will ask you for permission to install some drivers, once you gave the permission and the drivers are installed, the upload should work.
Success !! Thank you very much
And it’s working with TTN
Sorry for the inconvenience with the missing drivers.
it’s a big (and not easy) work so thanks to you !
