Hello,
We have the Raspberry Pi + RAK2245 gateway. We Configure the gateway successfully and it visible as connect on TTN.
We have RAK 5205 wistrio node. We have configured it also on TTN but gateway it not forwarding any data to TTN. We also tried with a different gateway and we got the data on TTN that means the node is properly configured. Can you help us with that?
Fomi
(Fomi Tong)
February 26, 2019, 9:52am
2
Hi, @Alluvium_2019
Firstly, please refer to the following document to check the configuration of RAK2245:
https://downloads.rakwireless.com/en/LoRa/RAK2245-Pi-HAT/Application-Notes/
Also, you can refer to another topic on RAK forum:
I have the same environment, I mean TTN with RAK5205 working fine.
One important point to pay attention it is that you need to follow the activation instructions because RAK5205 AT interface has some restrictions, if I am not wrong about APP EUI. You can´t use you automatically created by TTN Application. Follow the instruction in the manual: Application Note for
WisTrio LoRa Tracker.
Tell after about the results.
[image]
Hobo
(Vladislav Yordanov)
February 26, 2019, 9:54am
3
What would be the reason for the restriction for the APP EUI?
Fomi
(Fomi Tong)
February 26, 2019, 10:01am
4
Yes, it is a possible resean.
I’ve ever written a very detailed tutorial about how to use RAK2245 with loraserver.io or TTN.
I think it may be useful for users/developers.
Hello Fomi,
Already refer this document and follow all the step so that it show connected to TTN. Please refer the SS for your reference.
juankgp
(Juan Carlos Gutiérrez)
July 11, 2019, 4:01am
6
Please could you repair the link because is down
Fomi
(Fomi Tong)
July 11, 2019, 4:24am
7
Hi @juankgp ,
Done. Please check again.
