@nero we actually have a script that helps us flash and burn the firmware. Also regarding the code that you sent I have already written that in the user_app.c file. I can probably try to fill some sample temp, humidity values to see if those are being sent or not.
Also I had a question:
This is what I see on tera-term when I flash my code when the code is flashed and ran on the board. So my question is below you can see that the log of sensor data can be observed via uart (I have cut out the IP and Port numbers). And we also see that commands sent to BG96 are echoed to same uart channel. How to use same uart channel to print any debug messages
| ___ / _ \ | | / / | | | () | |
| |/ / /\ | |/ / | | | | _ __ | | ___ ___ ___
| /| _ || \ | |/| | | '/ _ \ |/ _ / __/ __|
| |\ | | | || |\ \ \ /\ / | | | __/ | /_ _
_| __| |/_| _/ / /||| _|_|_||//
AT+CSQAT+CSQ
+CSQ: 14,99
OKAT+QICSGP=1,1,"fast.tmobile.com"
OKAT+QIACT=1
AT+QIACT=1
OKAT+QIACT?
AT+QIACT?
+QIACT: 1,1,1," "
OKAT+QIOPEN=1,0,"UDP"," ", ,1,1
OKAT+QISTATE=0,1
AT
+QIOPEN: 0,0
+QISTATE=0,1
+QISTATE: 0,"UDP"," ", ,1,2,1,0,1,"uart1"
OKAT+QISEND=0,95Tem:-0.00;Hum:0.00; Pre:-0.00; Lat(0-N,1-S):0,0.000000,Lon(0-E,1-W):1,0.000000; Battery:-0.00;
AT+QISEND=0,95
SEND OKAT+CLOSE=0
