Rak4631 Not showing up in Devices/drives
Sorry about that!
I work with a traditional RAK4631->Arduino BSP/RAK4631->R-RUI3, but I think that the Meshtastic has a different bootloader and firmware.
I am not familiar with the Meshtastic.
Just for curiosity, Why you choose this model instead the regular one?
Cláudio
Welcome to RAK forum @Pattognozzi ,
The LED indicators shows that you have a Meshtastic firmware, where you able to connect to your device via mobile app, webclient or CLI?
If not, can you share a screenshot of device manager for me to see the port being detected?
Don’t you see any unusually damage or burnt marks on the board? Also, if you are capable, will you be able to measure the current consumption and voltage levels of your board?
Hi thank you,
Yes so when it is powered up the device is visible in the Meshtastic app via Bluetooth but I’m unable to connect because the firmware needs to be updated first.
The device looks to be in good condition and I see no burnt out components.
Well Lora via Meshtastic is a new hobby I’ve gotten into. I’ve never interacted with arduino before and this set up from RAK comes pre-assembled and programmed to work with Meshtastic. It’s considered the best unit for this so it was an easy choice in my opinion.
Hi @Pattognozzi ,
Based on the image, it seems it is detected.
Yes. But it will not show up as a driver on the PC, double pressing the reset button does nothing. Please see the photo in the first post. As a result I’m not able to update the Meshtastic firmware. And I’m also not able to connect to it via Bluetooth because the firmware the product is shipped with is so out of date.
Does anyone know of a way to fix this? Thats what I’ve been explaining with this post. The PC detects the device but there is no way to get it to appear as a driver. As a result there is no way for me to update the firmware.
Hi @Pattognozzi ,
Thank you for your patience. This confirms that you have Meshtastic FW working.
With regards to device not going to DFU. It can be that the reset button is not working. Will you be able to test it? Possible way is if you press and hold it, the LED should be out. If the reset is working, this is a strange issue which can probably get fixed if the bootloader is updated via external tool like Jlink or RAKDAP1 (since USB is not working).
Thank you very much for the advice, I appreciate it
Hi there, I just received the 4x RAK4631 + RAK19003 I ordered and it appears that I am having the same problem with 2x of the devices where the reset button does not function and I cannot get those units to show up as drives on my PC to then install the meshtastic firmware. Is there a way to fix this hardware or will you just send 2x replacement units with working reset buttons?
Welcome to the forum @MarkyMark
Are you using Windows?
Are the RAK4631 showing as COM port when you plug them into a computer?
No I was unable to resolve the issue unfortunately. I was given this link to flash to unit, it was just more technical than I was able to take on.
Beegee - The issue is that the until will not enter DFU mode when double pressing the reset button. It will show up as connected to a COM port on the PC but there is just no way to get the update file on it. And since the ship with such an outdated firmware you can’t connect via Bluetooth.
Hi Bernd, yes, it did should up as a COM port on Windows, but never a drive. However, I was able to find a workaround that appears to have worked to install the meshtastic firmware, though some errors were thrown during the install the process so am not completely sure it’s “perfectly” installed. The Reset button still does not function, but I am able to send messages, etc. within the Meshtastic ecosystem. My method for getting Meshtastic working was to plug in the RAK into my PC via USB, then I used the Nordic DFU iOS to attempt to install the meshtastic frimware zip which failed, but during the failure it put the RAK into the (boot?) mode where it could be seen as a drive on my PC. From there I followed the drag-and-drop procedure moving the Meshtastic firmware onto that drive. It installed (something) but threw an error at the end of the install. But the RAK appears to be working with meshtastic normally. I still would like to have units with working Reset buttons.
Does a normal reset work? I mean, push it once and the RAk4631 resets?
No, the reset button doesn’t seem to do anything. I tried mixing and matching the modules and baseboards I have on hand and it appears that all the modules are functioning normally, it’s just the 2x baseboards that have a faulty reset switch (or whatever the actual root-cause is).
Can you make a close-up (macro) picture of the reset button on the two boards.
The Reset line in the nRF52 is “hard-reset” (still can be changed to an GPIO, but bootloader doesn’t do that).
It is pointing to a problem with the button itself. Maybe a bad solder point or damaged button.
Hey Bernd, I just emailed your colleague Carl Rowan the best images I could take with my phone, I don’t have a special macro lens/camera, sorry.
Hi Mark,
thanks. We will check it.
Hello MarkyMark. Did you guys ever find a solution? I am currently having the same issue with two WisBlocks I just bought
For anyone new to RAK and having this issue with a new board (eg. just bought a RAK4631 Meshtastic Starter Kit and USB drive not mounting) - I just had to flip the black switch towards the USB port!
If the green light is solid (or solid and then some flashes) you’re good to go. Bluetooth pin is 123456 if you don’t have an LCD.
Welcome to the forum @jakec
Can you please show which “black switch” you flipped?
The RAK4631 Starter kit doesn’t have any switch.
Or do you mean the WisMesh Base board RAK19026?
