I finally found the problem: In Application Server Integration / MQTT Topic template Setup the fields were blank
I registered the following values and the packages have already started to arrive without coding
Thanks for your help and patience.
Thanks for sticking it out and finding the actual issue to fix, these systems can indeed be frustrating when it’s unclear how to get them to do what you need.
@cstratton sorry to raise old thread but a question on one of your comments. One of the capabilities of the RAK gateway is to be a network server that provides mqtt to an application server. Whilst most would use chirpstack or TTN I am using Home Assistant to receive and decode the payloads I receive from the RAK network server.
I have used TTN and built my own Chirpstack server that both send data into my home assistant. However I am questioning why I just dont use the RAK network server to send data directly to home assistant and bypass TTN or my own chirpstack server.
What am I missing here?
