well thanks all guys for your reply
i just see on TTN :
“I think V3 PCN clusters become available in preview in May.”
until that i will try to play with the loraserver in a VM
regards
i just see on TTN :
regards
this image is only for RAK devices ? or i can use it with my RG186 gateway ?
It is for anything supported, Linux based in general. Actually there is official support for your exact gateway.
https://www.loraserver.io/lora-gateway-bridge/gateway/laird/
This is the official page guide. All the instructions apply for your gateway
Take a look, give it a try and if you get stuck we will try to help
i just download twice the image file …
it seem corrupted ! can’t open it … that start good !
What platform are you trying to install it on ?
i’m using Windows … the rar file seem corrupted, i can’t extract the image file !
You mean the *.rat.gz. I just downloaded it, used 7 zip to extract it and ran it in the CLI.
It runs, except that it can’t find the MQTT broker, which is expected as I have not installed one on the machines, as I mentioned my setup has all components on the Gateway.
Are you sure you downloaded the right archive?
By the way why are you installing it on Windows ???
Additionally you need to have an MQTT Broker (Mosquitto for example)
Than you need the LoRa Server , thant you need the LoRa Application server
So you need to run the MQTT broker and point the packet forwarder to the Gateway bridge, it will connect with the MQTT Broker which will publish messages in topics. Than the LoRaServer subscribes to those. And than you got the Application server on top. As you can see quite fun to configure on Windows.
Better get a Raspberry Pi and have it all dumped there, :):)
Ah another thing is that the binaries are see like viruses by your antivirus software. No worries they are false positives, however do not expect to extract the archive or run the service while your antivirus is up.
Hi Hobo,
well it is an archive of virtual machine …no ? then why not running it under windows OS ?
the archive file seem corrupted when i try to unrar it from my Windows machine (i’m using an old Winrar version).
i will give it a try to download it on another machine which run Ubuntu.
Hi @phil31 ,
I have just downloaded the image to check if it works. Seems ok to me. In the RAR file there is an ISO image. Mount it using virtual box for example (or whatever VM you are using). Try to install this way and everything should be up and running
Next you need to set up the connection between your LAIRD GW and the LoRaServer.
You can find the tutorial here: LoRa Server Lair Setup. Do not forget you need to configure your MQTT broker as @Hobo mentioned .
You can edit the broker credentials, loraserver and etc. configurations from console :
sudo vi /etc/lora-gateway-bridge/templates/lora-gateway-bridge.toml
sudo vi /etc/lora-app-server/templates/lora-app-server.toml
sudo vi /etc/loraserver/templates/loraserver.toml
hello all
no way, i just try to open the rar archive file, even under Ubuntu 18.04, that say me that the file archive is corrupted !!
can’t open the rar file neither with Windows or Ubuntu
is there any other location that i can download it ?
or may i use other provider as TTN to try class C ?
lorio.io is working with class C ?
i try to install directly the loraserver.io under my Unbuntu VM, but 'im stuck !
I would suggest that you take care of your OS. If me and @velev both downloaded the file from the same location and we were both able to open it than this suggests that the issues is not with the file itself.
Perhaps we can give you a link to the ISO.
I will extract the archive and upload the image in my personal cloud space. Will share it later today.
thanks Hobo, wait your link
Hi @phil31,
The link to the ISO:
https://drive.google.com/open?id=1VHOZB8l1NmPXAUD3EhcNgFMt_PrOzN41
Try to use this one for the VM, should be able to install it.
thanks Hobo, iso downloaded.
i run it … but what is the login/pass ?
regards
Np let me know ow it goes.
Try admin/admin, if you haven’t already that is
there is only 2 users : “postgres” and “rakwireless” !
well rakwireless/rakwireless works !
now i will check it :o)
ty
np, glad you found it on your own
