Hi @Hobo,
I tested at 27dBm and it worked better. I switched it back to normal now.
thanks!
Hi @steven1,
So now you get the join accept further… Ight really be the antenna. I would not ha e expected this.
Perhaps you can ask @kenyu to send another antenna, explaining the situation.
Apologies for the inconvenience.
Vladislav
Which antenna may be the culprit though, the one on the node, or that of the gateway?
I’ll try to contact @kenyu. thanks for your help!!
Hi @steven1,
As for both just in case, they are not really expensive. Should be the node antenna, assuming the node is otherwise OK, as the gateway uses iPEX antenna and I don’t think rak offers antennas with iPEX connector that are not Lora. Unless you got the 433 version. No point thinking about it, get a new set and test. We will know for sure.
Again sorry for the trouble.
Vladislav
I contacted @kenyu ia the messaging of this forum, but I have not received any replies. Is there an email I should use maybe?
