Receiving RAK7249 LoRaServer MQTT feed with Arduino
You shouldn’t have touched the LoRa Gateway Bridge settings at all. That’s what I’ve been explaining over and over - that MQTT communication is internal to the gateway alone. The gateway bridge carries only raw traffic, it does not carry application topics. And even if this were a mis-statement, an MQTT client ID describes a client, not the traffic. Each client has its own ID, fixed or dynamically assigned. It’s not usually very relevant except in MQTT broker logs.
No particular idea what’s going on with the Arduino, but very concerned about apparent misconfiguration of the gateway.
One thing you can do with an ordinary MQTT client is subscribe to wildcard topics, I don’t know if your Arduino library supports that or not. It’s also possible that a message is being received, but your parsing code is getting (permanently?) stuck on the way to trying to print it. Generally you shouldn’t send ASCII strings over LoRaWAN as they are horribly inefficient.
I’m not familiar with your PC MQTT client but with something like mosquitto_pub you could also easily re-inject already received traffic by publishing it again with slight variations, or mock traffic entirely. That might let you iterate and figure out what exactly is causing difficulties for the Arduino.
Hi Chris. Leave the LoRa Gateway bridge settings alone: I get that. I was indeed returning the setting to its original. I had put the ClientID in there some time ago, so I too it out.
I have used an external site that allows you to publish and subscribe and that worked well.
I’m sending HEX coded payloads.
The thing is that the parsing code works of with one of the above topic but the same sketch doesn’t work with the other one.
Secondly, both topics (above) with heaps of traffic are visible on MQTT.fx client.
I think I’ll start aver. Factory reset of the 7249 and go from there.
Thanks for your insights. Regards
I’d try publishing mock messages back into the application broker from the PC, and see what the Arduino gets.
Eg, you could take the message that works and change it bit by bit towards the one that doesn’t. Does it work if you keep the topic the same but change the contents? Or the reverse?
Hi Chris. Thank you for your response. I guess the “verbose” version of what I did is pretty much along the lines that you recommend. I started by setting up an Ethernet server, then an Ethernet client to make sure that the IP and MAC addressing was working for the Arduino. Then I set up an Arduino MQTT client that published to a web site, then subscribed to that site and read the message back. Factory reset the 7249 to ensure the MQTT was pristine, then chose the built in LoRa Server. I watched the packet logger on the 7249, and also set up the MQTT.fx to make sure the build-in server was doing its thing, and then saw the payloads appear on the MQTT.fx. Also looked on the IP Scanner to see that the IP address was operating.
I put this topic into the Arduino Client -
“application/2/device/01f3b8fb5a1c1050/rx”
It took a few seconds but I got messages. The payload was printed on the monitor. In my view it worked perfectly, and remained working like that for a day or so.
Then I changed the topic to -
“application/3/device/00033bbcff12a631/rx”
I got a message -
“Attempting the MQTT connection …”
Followed by -
“The client is connected”.
I got nothing after that. So an absolutely working MQTT client stopped working after changing the client from -
to -
“application/3/device/00033bbcff12a631/rx”.
So I feel that I have already done the this that you suggest.
However, starting from scratch might be useful.
Thank you for your continued assistance. Regards.
That’s a change of topic. The clients are the RAK7258’s network server which is publishing messages, and your PC software and Arduino software which are subscribed to them.
What I suggested what that you use your PC MQTT software to publish mock messages back into the MQTT broker, and see if the Arduino gets them.
You could first try to exactly repeate the working messages. Then you could do things like send the payload of the non-working message but to the topic of the working one. Or the other way around.
And I also suggested you look into seeing if the Arduino MQTT software supports wildcards in the topic subscriptions the way standard MQTT client software does. So see if you can subscribe to “application/*”
Hi Chris - Thank you again, especially for your patience.
With regard to what you suggested re wildcard in the topic. It appears that a “+” works. On a “*” or a “#” the monitor goes round and round at hi speed telling me I’m attempting to connect. I’m connected. I’m attempting to connect. I’m connected … However with a “+” the topic becomes -
mqttClient.subscribe(“application/+/device/+/rx”);
and I get the following screen shot -
You will see that I never go to any other application, eg application 3, in the subscribed topic
Thanks. Regards
Hi Chris. Progress I think.
mqttClient.subscribe(“application/+/device/+/+”);
ie, the uplink, down link, join etc to a wildcard, and then I restarted the Arduino node and here is the screenshot -
You will notice that the second-to-bottom message is from “application 3” and you will see the topic ends with “join”.
So it appears that that node is attempting to join but there is no subsequent uplink.
How di I fix that, please?
You’d have to figure out why it is failing.
Are join accepts being generated, eg in the gateway screen do you see it transmitting replies?
Often this is a timing problem on the node, but it can be a configuration problem, etc. Really debugging it can require digging deep into node firmware.
Hi Chris. I cld not work out why messages from that particular node cld not be seen. Did a lot of research and finally decided maybe I’ll set up a brand new node. different code, different message. I did that and the Arduino MQTT Client now works perfectly. Very happy about that. Many thanks for all your help. Best wishes for 2021. Kind regards.
Hello, again. Same topic, slightly different problem.
I am using RAK7249/4240 with in-build LoRa server. I have built an Arduino MQTT client, and connected it to the 7249. I have a couple of nodes working, one sending DHT22 temp/humidity information, the other sending “Hello, Ryan”. The Arduino MQTT client is subscribed to messages from these two nodes. I have managed to get this configuration working perfectly. I can re-set the nodes individually, see the “join” messages and the “Rx” messages thereafter on both the Arduino MQTT and the Laptop MQTT.fx. And I can see the payloads. Very happy.
I also have MQTT.fx running on a laptop, also connected to the 7249 and I can see the same messages/payloads on the laptop screen. So all good.
On the weekend I upgraded to RAK7249 firmware to the latest version. I must also point out that while trying to remove the ethernet RJ45 plug a couple of weeks ago, the RJ45 pcb-mounted socket came off in my hand. While I await a replacement, I tried to connect via RAK7249 access point. This has been the subject of a separate thread in that I could not get the 7249 to establish a client relationship with my Linksys LAPAC access point so that I could keep my applications running. Thanks to Todor’s very generous assistance in a middle-of-the-night intervention, I now have that client relationship working fine
The problem now is that while I can see the “join” requests and the “Rx” responses and payloads from my 2 nodes on the laptop MQTT.fx, I can only see the “join” request and not the “Rx” responses on my Arduino MQTT client nor the payloads.
There has been no change to the Arduino hardware, The IP address of the server is the only software change, and I am messaged that the Arduino has connected, and I do get the “join” message.
The only real change is the firmware upgrade to the 7249.
Any suggestions, please.
Use your PC-based subscription to figure out what’s different about the feed, particularly between what you receive there and not at the Arduino, and adjust your Arduino sketch accordingly.
Look at things like topic, encoding (formats or funny characters) and even overall length
Hello again. I’ve got it going. The problem was the buffer size. Changed it from default 256 to 512 and it burst into life. This has taken me months of researching, reading trying. One of the reasons that I didn’t tumble to this earlier was that I read the buffer size in the .h file as the maximum ALLOWED, when in fact it was just any old arbitrary number that the author chose at write time, ie 256. Changed to to 512 and all so good. I know it sounds trivial, but, boy, have I learned lot about LMIC and PubSubClient libraries over the past few months. Many many thanks for all your help earlier on. Most appreciated. Regards.
Hello. My next issue in this project is decoding the DHT22 environment data from the payload. at the Arduino MQTT Client
Here is the output of the compiler -
Using board ‘mega’ from platform in folder: C:\Users\johno\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3
Using core ‘arduino’ from platform in folder: C:\Users\johno\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3
Detecting libraries used…
“C:\Users\johno\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++” -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR “-IC:\Users\johno\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3\cores\arduino” “-IC:\Users\johno\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3\variants\mega” “C:\Users\johno\AppData\Local\Temp\arduino-sketch-AAB4E1EA55727EB640A0AF04A530CE7B\sketch\sketch_apr5_v9.0.ino.cpp” -o nul
Alternatives for LMIC.h: []
ResolveLibrary(LMIC.h)
→ candidates: []
Compilation error: Error: 2 UNKNOWN: exit status 1
Here is my code (hope I’ve presented it in the right way.).
The issue is the decoding loop in the callback area. It just doesn’t work.
Arduino MQTT Client v9.0
Extracting DHT22 data from payload.
Arduino Mega + genuine Arduino Ethernet Shield2
Subscribes to topic “application/+/device/+/+”
IPaddress RAK7249 in-built server 192.168.1.227 (Barn) or 192.168.1.250
(Network Room) Arduino ethernet shield MAC address is A8:61:0A:AE:6A:0B
Arduino PubSubClient - MQTT Client Library Encyclopedia
//#include <Adafruit_Sensor.h>
//#include “DHT.h”
#include <LMIC.h>
#include <Ethernet.h>
#include <PubSubClient.h>
#include <string.h>
// float temperature;
// float humidity;
int data[5];
int dataStart;
int dataEnd;
float rawTemp;
float rawHumid;
int i;
byte mac[] = {0xA8, 0x61, 0x0A, 0xAE, 0x6A, 0x0B}; // MAC address Arduino Ethernet Shield MQTT client
IPAddress ip(192, 168, 1, 51); // Static IP address Arduino MQTT client
IPAddress server(192, 168, 1, 227); // Static IP address RAK7249 built-in LoRa server Barn
void callback(char *topic, byte *payload, unsigned int length)
Serial.print("\nMessage arrived\nTopic\n [");
Serial.print(topic); // Print topic
Serial.print("]\n");
Serial.print(“Payload\n “);
for (int i = 0; i < length; i++)
Serial.print((char)payload[i]); // Print payload
Serial.print(”\n”);
if (strstr(payload, “01f3b8fb5a1c1050”)) // DTH22 environment message? Search for devEUI.
dataStart = int(strchr(payload, ‘data":"’)); // point to the start of the environment data
dataEnd = int(strchr(payload, ‘data_encode’) - 14); // point to the end of the environment data
for (i = dataStart; i < dataEnd; i++)
data[i] = payload[i]; // extract the environment data to a new string
// isolate temperature
rawTemp = data[0] + data[1] * 256;
// float -> int: this uses the sflt16 datum (https://github.com/mcci-catena/arduino-lmic#sflt16)
uint16_t payloadTemp = f2sflt16(rawTemp) * 100;    //alt code: temperature = sflt162f(rawTemp) * 100;
// isolate humidity
rawHumid = data[2] + data[3] * 256;
uint16_t payloadHumid = f2sflt16(rawHumid)* 100;
//humidity = sflt162f(rawHumid) * 100;
Serial.print("\n    Environment:  ");
Serial.print("Temperature: ");
Serial.print(payloadTemp);
Serial.print("° C");
Serial.print("  Humidity: ");
Serial.print(payloadHumid);
Serial.print("% rH");
EthernetClient ethClient;
PubSubClient mqttClient(ethClient);
void reconnect()
while (!mqttClient.connected()) // Loop until we’re reconnected
Serial.print("\nAttempting MQTT connection…");
if (mqttClient.connect("arduinoClient9"))                 // Attempt to connect
  Serial.print("\nThe client is connected.");
  mqttClient.subscribe("application/+/device/+/+");
  Serial.print("\nFailed, rc = ");
  Serial.print(mqttClient.state());
  Serial.print("\nTry again in 5 seconds.");
  delay(5000);}                                                          // Wait 5 seconds before retrying
Ethernet.begin(mac, ip);
delay(5000); // Allow the hardware to sort itself out
mqttClient.setServer(server, 1883);
mqttClient.setCallback(callback);
if (!mqttClient.connected())
reconnect();
mqttClient.loop();
I’m hoping that some one can point out where I’m going wrong. Thank you. Regards
I’ll get the right yet.
Here’s the code that is not working -
Serial.print("Payload\n ");
Serial.print("\n");
dataStart = int(strchr(payload, 'data":"'));                  // point to the start of the environment data
dataEnd = int(strchr(payload, 'data_encode') - 14);           // point to the end of the environment data
uint16_t payloadTemp = LMIC_f2sflt16(rawTemp) * 100;         //alt code: temperature = sflt162f(rawTemp) * 100;
// isolate humidity
uint16_t payloadHumid = LMIC_f2sflt16(rawHumid)* 100;        //humidity = sflt162f(rawHumid) * 100;
What is the purpose of including LMiC in the sketch.
What device is sending the DHT22 data?
If you coded the device payload format, then you just reverse the process on the Arduino when you an incoming MQTT uplink message.
Hi Nick. Thank you for your reply. I mucked-up presenting the code in my post. However you will see in the final piece that I sent -
Unit16_t payloadTemp = LMIC_f2sflt16(rawHumid) * 100
You need the LMIC library for this.
I am using an Arduino UNO + Dragino LoRa shield + DHT22 to do the sending. That part is working very well. The code comes from the RAK4260 GitHub page.
I think my problem is not using compatible data types.
Most likely. Mostly we’d not transmit a float as it gets messy turning the byte array back in to a float in a variety of languages. And loading LMiC for just that function is a proverbial sledgehammer to crack a nut.
When you take a reading that is a float, multiple by 10’s for the precision you need and send that. Then divide appropriately at the other end.
So humidity reading of 45.2% gets x 10 and sent as an integer of 452 - very easy to decode in JavaScript, PHP, Python as well as C, and you just divide by 10 to get back to the original value.
The RAK4260 doesn’t do any form of Arduino as it’s all Microchip with ASF and MLS - which repro are you thinking of?
Not sure which which example you are thinking of - bit confused as that’s not a RAK4260 repro, although someone has pointed out that the 4260 can do a sort of LoRaWAN on Arduino using Bestwan.
I’m using this one -
I am using an Arduino Mega + Dragino LoRa shield. I have had a lot of difficulty getting a node to work on AU915, however, recently I have been successful. In the meantime, I discovered this RAK/Demo code. I trust anything RAK, so set it up and it worked first time. I have since used this code as the basis for other sensor applications. Making great progress.
As I have been discussing, I’m using an Arduino Mega + Arduino Ethernet Shield v2 for the MQTT client connected to a RAK7249 gateway. I’v managed to get that going perfectly. The problem there was the size of the buffer.
Now I’m trying to decode the payload and have pretty much got that going as well.
I really appreciate all your advice and help. Regards.
