i want to send data without using Uart. It mean my device first get connect with gateway then send data every 1 minute
" for(i=0;i<0x800000;i++);“If you want to delay,RUI has special delay functions"rui_delay_ms(x);”, x unit:ms.
That’s not the right way to write it either,you’d better refer to “lora_config.c”
This
this is the same error,you’d better refer to this usage in app_RAK811.c:
In this case:when RUI_UART1 received data ,then sent these data through lora. Also you can send data directly through lora, but not in the form of a string.
for example:
uint8_t ss[64];
strcpy(ss,“AABBCC”);
rui_lora_send(2,ss,strlen(ss));
i corrected my mistakes
MY code
#include “rui.h”
#include “board.h”
int main(void)
int i;
static RUI_RETURN_STATUS rui_return_status;
RUI_LORA_STATUS_T app_lora_status; //record status
rui_lora_get_status(false,&app_lora_status);;//The query gets the current device status
static uint8_t sensor_data_cnt=0; //send data counter by LoRa
rui_init();
char lora_id_1[32] = {'0','0','3','E','B','D','4','9','5','B','1','0','6','2','2','5'};
char lora_id_2[32] = {'7','0','B','3','D','5','7','E','D','0','0','2','7','A','8','6'};
char lora_id_3[32] = {'B','0','9','7','5','1','5','5','4','6','8','9','8','1','0','E','C','3','9','0','7','4','6','1','A','9','7','F','2','9','E','D'};
//'\0'
static uint8_t a[80]={0x33,0x23,0xAA,0xFF};
//void rui_uart_recv(RUI_UART1, 2, 1);
while (1) {
rui_lora_get_status(false,&app_lora_status);//The query gets the current status
rui_running();
rui_delay_ms(1000);
rui_lora_set_region(EU868);
rui_delay_ms(1000);
rui_lora_set_work_mode(RUI_LORAWAN);
rui_delay_ms(1000);
rui_lora_set_dev_eui(lora_id_1);
rui_delay_ms(1000);
rui_lora_set_app_eui(lora_id_2);
rui_delay_ms(1000);
rui_lora_set_app_key(lora_id_3);
rui_delay_ms(1000);;
rui_lora_set_join_mode(RUI_OTAA);
rui_delay_ms(1000);
rui_lora_join();
rui_delay_ms(1000);
rui_lora_set_dr(0x05);
rui_delay_ms(1000);
//rui_lora_send(2,"AABBCC",3);
rui_lora_send(8,a,3);
THen i compil
Hi,@oleksander
You’d better take a look at demo code about RAK811:https://github.com/RAKWireless/Products_practice_based_on_RUI/tree/master/based%20on%20RAK811/app_RAK811
demo code must use at Command, if i do not want use at command, what i must do?
Hi,@oleksander
We have fixed weak definition of rui_uart_recv(),you could compile your code again.Also you could define this function empty .
I compile my code again
I have a question. RUI commands can be used without uart, the code works independently, as in the example here https://github.com/RAKWireless/RAK811_BreakBoard
yes, write your email and i send my file
I had reply you by email,pls check it.
i see i answered you too, check it out
if i use app Rak811.i must send AT+Command. If i do not want send AT+command, what i must change in my code?
Hi, have you find any solution to this?
here what is 2 ?
char b[3] = {0};
const char Buffer;
uint8_t BufferSize;
const char a[3]={0x11,0x22,0x33};
int i;
while(1)
rui_uart_mode_config(RUI_UART1, RUI_UART_UNVARNISHED);
rui_uart_init( RUI_UART1, BAUDRATE_115200);
rui_uart_send(RUI_UART1, a, 3);
rui_uart_recv(RUI_UART1, Buffer, 1 );
for(i=0;i<;i++);
sprintf(b, "%02x",Buffer[i]);
RUI_LOG_PRINTF("%c",Buffer[i]);
RUI_LOG_PRINTF("%s", b);
RUI_LOG_PRINTF("%s", Buffer);
RUI_LOG_PRINTF("\r\n");
DelayMs(2000);
How rui_uart_recv function i can Used? i did not get data which i send?
It is the pointer of the data. The documentation of rui_uart_recv function is here https://docs.rakwireless.com/RUI/rui-interface-general-format/#rui-uart-receive
