Solved: Corecell reset GPIO errors with Raspbian "bookworm" and rak_common_for_gateway
Hi all,
this is for users with Raspberry Pi and “bookworm” Raspian:
I had the known GPIO errors when restarting the packet forwarder using “sudo gateway-config”, for example. When it’s restarting, the reset-gpio-pins are not working since the sysfs-gpio commands are not supported anymore with raspbian bookworm.
Instead of sysfs-gpio, you now have to use gpiod as a method to access and set/reset the GPIOs.
To solve the issue (which otherwise always needs a powercycle to bring up the gateway again), we have to change the sys-fs commands to gpiod. Since there is nothing to “init”, I commented-out the init task at the bottom as well.
In the following code I just commented-out the original commands in case you want to roll-back.
/opt/ttn-gateway/packet_forwarder/lora_pkt_fwd/reset_lgw.sh:
#!/bin/sh
# This script is intended to be used on SX1302 CoreCell platform, it performs
# the following actions:
#       - export/unpexort GPIO23 and GPIO18 used to reset the SX1302 chip and to enable the LDOs
# Usage examples:
#       ./reset_lgw.sh stop
#       ./reset_lgw.sh start
# GPIO mapping has to be adapted with HW
SX1302_RESET_PIN=17
WAIT_GPIO() {
    sleep 0.1
init() {
    # setup GPIOs
#    echo "$SX1302_RESET_PIN" > /sys/class/gpio/export; WAIT_GPIO
#    echo "Init reset_lgw.sh done"
    # set GPIOs as output
#    echo "out" > /sys/class/gpio/gpio$SX1302_RESET_PIN/direction; WAIT_GPIO
reset() {
    echo "CoreCell reset through GPIO$SX1302_RESET_PIN..."
   # echo "1" > /sys/class/gpio/gpio$SX1302_RESET_PIN/value; WAIT_GPIO
     gpioset gpiochip0 $SX1302_RESET_PIN=1
     sleep 0.1
   # echo "0" > /sys/class/gpio/gpio$SX1302_RESET_PIN/value; WAIT_GPIO
     gpioset gpiochip0 $SX1302_RESET_PIN=0
     sleep 0.1
term() {
    # cleanup all GPIOs
  #  if [ -d /sys/class/gpio/gpio$SX1302_RESET_PIN ]
  #  then
  #      echo "$SX1302_RESET_PIN" > /sys/class/gpio/unexport; WAIT_GPIO
  #  fi
     gpioget gpiochip0 $SX1302_RESET_PIN
case "$1" in
    start)
    term # just in case
 #   init
    reset
    stop)
    reset
    term
    echo "Usage: $0 {start|stop}"
    exit 1
esac
exit 0
In the file start.sh in the same directory as reset_lgw.sh, you need to do the same.
/opt/ttn-gateway/packet_forwarder/lora_pkt_fwd/start.sh:
#! /bin/bash
# Reset iC880a PIN
SX1301_RESET_BCM_PIN=17
#echo "$SX1301_RESET_BCM_PIN" > /sys/class/gpio/export
#echo "out" > /sys/class/gpio/gpio$SX1301_RESET_BCM_PIN/direction
#echo "0" > /sys/class/gpio/gpio$SX1301_RESET_BCM_PIN/value
gpioset gpiochip0 $SX1301_RESET_BCM_PIN=0
sleep 0.1
#echo "1" > /sys/class/gpio/gpio$SX1301_RESET_BCM_PIN/value
gpioset gpiochip0 $SX1301_RESET_BCM_PIN=1
sleep 0.1
sleep 0.1
#echo "$SX1301_RESET_BCM_PIN" > /sys/class/gpio/unexport
gpioget gpiochip0 $SX1301_RESET_BCM_PIN
./set_eui.sh
sleep 0.2
#./update_gwid.sh ./local_conf.json
sleep 0.5
./lora_pkt_fwd
Without this modification, a restart of the packet forwarder did not work for me and instead it required a powercycle of the whole gateway, to bring back the lgw to its initial state.
Of course, a cleaner look can be achieved by deleting all old commands and unsued methods like “WAIT_GPIO()” and such. I’ll post a cleaned up version below.
Cleaned up versions:
#!/bin/sh
#       - export/unpexort GPIO17 used to reset the SX1302 chip and to enable the LDOs, adapted to gpiod (since raspbian bookworm).
# Usage examples:
SX1302_RESET_PIN=17
reset() {
     sleep 0.1
     sleep 0.1
term() {
     # "unexport" (set back to "input" by reading its value)
case "$1" in
    start)
    term # just in case
    reset
    stop)
    reset
    term
    exit 1
esac
exit 0
#! /bin/bash
# Reset iC880a PIN
sleep 0.1
sleep 0.1
sleep 0.1
./set_eui.sh
sleep 0.2
sleep 0.5
./lora_pkt_fwd
