Carl are you sure this wind sensor you recommended works with this rak 4630 board?
https://www.lcsc.com/product-detail/Specialized-Sensors_Ubibot-JXBS-3001-FS_C843317.html
That wind sensor has the same PN as what we used on the solution example so that will work.
Also, any wind sensor will work with RAK4630 as long as you can get its data.
We were able to send it data and verified that it was the same as the datasheet and the sensor never responds back. We verified from the datasheet you sent me here on the oscilliscope as you can see, and the sensor does not respond.
Wind Sensor Data Sheet
Hi carlrowan, I am using rak4631 to send data to the gateway through lora. I have a little doubt about Lora transmission interval. The default is #define LORAWAN_APP_INTERVAL 20000. But I want to know what is the minimum value that can be set?
Please donβt hijack existing threads. This is a new question and should be in a new thread.
