Greetings,
Does the 19007 require an external diode inline with the solar panel? Or is such protection already offered on the board?
Cheers
Greetings,
Cheers
There is a diode already on the baseboard.
Dandy. Thank you kindly. ![]()
Say would you know what the max charge rate is for the solar input? Is it 350mA same as the usb C input?
Cheers
Same charge rate, both the USB and solar panel input are going to the same charger chip.
Thanks kindly also. ![]()
