I have the RAK 3212 - the dev board with the 3112.
My question is the function of the Jumper next to the USB-C connector. The documentation is not clear - hoping for guidance.
can you please confirm the function of this jumper.
Im looking to power the unit from a combo of TPS63020 (buck converter 4.2–> 5v or 3.3v). Im looking for an easy way to have the 3v or 5v power pins power off the attached sensors which are mix of 3v3 and 5v when the unit goes into deepsleep.
The jumper disconnects the output of the buck converter to the supply (VCC) of RAK3112 module.
Two things:
You can use this to measure the current consumption of the module. Put the ammeter in series on that header disconnection.
You can use to have a directly put power on the supply (VCC) pin via the header. I use this if I need to measure current using nordic power profiler kit in source mode.
i expecting a PPK2 in the post any day now - timing is perfect.
the jumper is going to be very handy.
can you point me at any documents on how to squeeze the power down as low as possible on this unit, im about to start chasing mA and deepsleep for long battery life.
I believe Wake on Radio (WoR) is not wired in for this unit, looking to solve the time drift problem (30m a day on sleep) without extra hardware if possible.
i guess that leads to the question on how best to use this forum - new posts on new topics, this one im thinking is on topic, but question stands.
Low current strategy depends on what application and usecase have. This can be a basic test that you can with Radiolib. This code is from another RAK3112 user as well.
