Dear all,
Thank you for reading (and hopefully helping)
I am dealing with one sensor location where I need 4 analog inputs for several sensors.
So far, I have tried working with with 2 5005-base boards, each coupled with a 13002 module. Both boards are connected to the same battery and the same solar panel and it does seem to work wel… I suspect power issues even though the solar panel is of sufficient wattage.
So I thought of another idea (and that is my actual question). Can I use a dual base board 19001 connected with 2 13002 modules? And if so, how would I be able to read the data from the analog pins on the second 13002 boards? Will they automatically become AIN2 and AIN3?
I simple have a dual base board lying around, so could be the easiest solution
Thanks for your help!
