Hi there. I’ve got two WisBlock prototype examples side by side. Each uses the 19011 dual IO base board, the 19016 DC power supply, 11310 core and 5860 cellular modem.
On one of the sets, the 5860 status LEDs do not come on, and the power supply LED blinks at a low brightness about 1/s. On the other one, the power supply LED is on steadily and bright, and the 5860 LEDs are blinking about 1/4s: BG77_STATUS (blue) LED with a long duty cycle and BG77_NET_STATUS (green) with a short one.
UPDATE: I did the obvious thing and swapped the 5860s between boards. I think it’s either a power or base board issue, because the problem still exists and it is independent of the modems.
