Issue:
my RAK 7240 does not include correct GPS locations. I included the system log.
Setup:
the GPS antenna is attached to the gateway and positioned outside. Running version 1.2.0064.
Reboot did not fix the problem.
NTP Time is enabled.
Thu Mar 25 11:01:59 2021 user.info lora_pkt_fwd[1650]: WARNING: [gps] could not get GPS time from GPS
Thu Mar 25 11:02:00 2021 user.info lora_pkt_fwd[1650]: WARNING: [gps] could not get GPS time from GPS
Thu Mar 25 11:02:00 2021 user.notice lora_pkt_fwd[1650]:
##### 2021-03-25 11:02:00 UTC #####
Thu Mar 25 11:02:00 2021 user.notice lora_pkt_fwd[1650]: ### [UPSTREAM] ###
Thu Mar 25 11:02:00 2021 user.notice lora_pkt_fwd[1650]: # RF packets received by concentrator: 0
Thu Mar 25 11:02:00 2021 user.notice lora_pkt_fwd[1650]: # CRC_OK: 0.00, CRC_FAIL: 0.00, NO_CRC: 0.00
Thu Mar 25 11:02:00 2021 user.notice lora_pkt_fwd[1650]: # RF packets forwarded: 0 (0 bytes)
Thu Mar 25 11:02:00 2021 user.notice lora_pkt_fwd[1650]: # PUSH_DATA datagrams sent: 1 (135 bytes)
Thu Mar 25 11:02:00 2021 user.notice lora_pkt_fwd[1650]: # PUSH_DATA acknowledged: 100.00
Thu Mar 25 11:02:00 2021 user.notice lora_pkt_fwd[1650]: ### [DOWNSTREAM] ###
Thu Mar 25 11:02:00 2021 user.notice lora_pkt_fwd[1650]: # PULL_DATA sent: 1 (100.00 acknowledged)
Thu Mar 25 11:02:00 2021 user.notice lora_pkt_fwd[1650]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Thu Mar 25 11:02:00 2021 user.notice lora_pkt_fwd[1650]: # RF packets sent to concentrator: 0 (0 bytes)
Thu Mar 25 11:02:00 2021 user.notice lora_pkt_fwd[1650]: # SX1301/SX1302 time (PPS): 1023910886, offset us 0
Thu Mar 25 11:02:00 2021 user.info lora_pkt_fwd[1650]: src/jitqueue.c:453:jit_print_queue(): INFO: [jit] queue is empty
Thu Mar 25 11:02:00 2021 user.notice lora_pkt_fwd[1650]: ### [GPS] ###
Thu Mar 25 11:02:00 2021 user.notice lora_pkt_fwd[1650]: # Invalid time reference (age: 1616670120 sec)
Thu Mar 25 11:02:00 2021 user.notice lora_pkt_fwd[1650]: # no valid GPS coordinates available yet
Thu Mar 25 11:02:00 2021 user.notice lora_pkt_fwd[1650]: ##### END #####
JSON up: {"stat":{"time":"2021-03-25 11:02:00 UTC","rxnb":0,"rxok":0,"rxfw":0,"ackr":100.0,"dwnb":0,"txnb":0,"cpur":0.0,"memr":0.0}}
Thu Mar 25 11:02:00 2021 user.info lora_pkt_fwd[1650]: INFO: [up] PUSH_ACK received in 18 ms
Thu Mar 25 11:02:01 2021 user.info lora_pkt_fwd[1650]: WARNING: [gps] could not get GPS time from GPS
Thu Mar 25 11:02:02 2021 user.info lora_pkt_fwd[1650]: WARNING: [gps] could not get GPS time from GPS
Thu Mar 25 11:02:02 2021 user.info lora_pkt_fwd[1650]: INFO: [down] PULL_ACK received in 18 ms
Thu Mar 25 11:02:02 2021 kern.info quectel-CM[8978]: requestRegistrationState2 MCC: 206, MNC: 1, PS: Detached, DataCap: UNKNOW
Thu Mar 25 11:02:02 2021 kern.info quectel-CM[8978]: Dail Failed 14
Thu Mar 25 11:02:03 2021 user.info lora_pkt_fwd[1650]: WARNING: [gps] could not get GPS time from GPS
Thu Mar 25 11:02:04 2021 user.info lora_pkt_fwd[1650]: WARNING: [gps] could not get GPS time from GPS
Thu Mar 25 11:02:05 2021 user.info lora_pkt_fwd[1650]: WARNING: [gps] could not get GPS time from GPS
Thu Mar 25 11:02:05 2021 user.notice lora_pkt_fwd[1650]:
##### 2021-03-25 11:02:05 UTC #####
Hi @momo232030,
Is your gateway in “Packet Forwarder” mode?
Also, could you send me the SN(serial number) of your gateway in personal message/dm so I could check if there is something wrong with the device?
