Accelerometer and GNSS issue
I’m using RAK4631,RAK5860,RAK19007 and RAK12034 Accelerometer sensor with Arduino BSP
Whenever I use Accelerometer interrupt , GNSS module continuously start power on/off and without interrupt it works properly. I’m using example code from RAK12034 library where it has used WB_IO1 as INT pin. I feel the INT pin is making the issue. I have connected RAK12034 to SLOT A. and RAK5860 to IO SLOT
@beegee Help me out here.
I don’t see a GNSS module in your list, only a cellular modem???
RAK12034 in Slot A has a conflict with the RAK5860. The interrupt pin is on the same GPIO as the PWR_KEY of the RAK5860:
==> Pin-Mapper
You can try RAk12034 in Slot D.
@beegee Thank you for quick response.
yes it’s cellular modem.
I’ll try with slot D and revert back to you.
