I’m trying to test a RAK15001 flash memory module on a dual IO base with 11310 core and 5860 cellular modem. I’ve installed the Adafruit_SPIFlash libraries and the example sketch is failing to compile with the following errors:
/home/phil/Arduino/libraries/Adafruit_SPIFlash/src/rp2040/Adafruit_FlashTransport_RP2040.cpp: In function 'void fl_lock()':
/home/phil/Arduino/libraries/Adafruit_SPIFlash/src/rp2040/Adafruit_FlashTransport_RP2040.cpp:51:3: error: 'rp2040' was not declared in this scope
rp2040.idleOtherCore();
/home/phil/Arduino/libraries/Adafruit_SPIFlash/src/rp2040/Adafruit_FlashTransport_RP2040.cpp:51:3: note: suggested alternative: 'p24'
p24
/home/phil/Arduino/libraries/Adafruit_SPIFlash/src/rp2040/Adafruit_FlashTransport_RP2040.cpp: In function 'void fl_unlock()':
/home/phil/Arduino/libraries/Adafruit_SPIFlash/src/rp2040/Adafruit_FlashTransport_RP2040.cpp:55:3: error: 'rp2040' was not declared in this scope
rp2040.resumeOtherCore();
/home/phil/Arduino/libraries/Adafruit_SPIFlash/src/rp2040/Adafruit_FlashTransport_RP2040.cpp:55:3: note: suggested alternative: 'p24'
p24
/home/phil/Arduino/libraries/Adafruit_SPIFlash/src/rp2040/Adafruit_FlashTransport_RP2040.cpp: In member function 'virtual void Adafruit_FlashTransport_RP2040::begin()':
/home/phil/Arduino/libraries/Adafruit_SPIFlash/src/rp2040/Adafruit_FlashTransport_RP2040.cpp:91:3: error: 'flash_do_cmd' was not declared in this scope
flash_do_cmd(cmd, data, 5);
/home/phil/Arduino/libraries/Adafruit_SPIFlash/src/rp2040/Adafruit_FlashTransport_RP2040.cpp:91:3: note: suggested alternative: '_flash_dev'
_flash_dev
Any insights? I’ve found reference to an alternative board manager for the RP Pico but want to make sure I’m not missing something obvious.
