Issue:Adding Mikrotik Lora9 Gateway to 7528
Setup: 7528 on same network as Lora9
LoRa® Server: 7528 Built-In
Details: I cannot seem to get my Mikrotik Lora9 gateway to connect to the 7528. I have added the Lora9 as a gateway under Lora Network Server -> Gateway, but it never checks in.
Nicholas
(nicholas)
May 28, 2020, 1:22am
2
If the network you are connecting to is wireless, you will need to open the firewall’s acceptance configuration.
Nicholas,
Everything is hardwired. So I have the WAN port of the 7258 connected to the same switch that the Lora9 is connected to.
I have disabled all firewall settings in the 7258 as well. I can ping back and forth between the devices, so the connection is there.
What port should a gateway be using to connect to the 7258?
