What product do you wish to discuss? RAK4631
What firmware are you using? platform.io
Computer OS? windows
What Computer OS version? windows 11
I am going to be using a RAK4631 with the RAK19010 base board. Since this board doesn’t have a usb port I am wondering what methods I could use to flash my firmware. I am a university student and have experience with arduino boards and a little bit of raspberry pi experience, so I’ve only ever used a direct usb connection to flash an arduino/communicate with the pi.
From what I’ve seen I could use the RAKDAP1 to flash code via the swd pins and can also use it to read serial outputs. This seems to be the preferred option since I am using the rs485 module on the I/O slot.
Would using the RAK5804 I/O expansion be able to flash code and receive serial comm via the USB connection? This wouldn’t be preferred unless I also got the dual I/O board so I could use both the I/O expansion and the RS485 modules.
Are there any other options I’ve missed? I need a board with the power slot since I’m supplying 5V. Apologies if I’m way off base here I’m still pretty new to all this.
