Analogwrite not working properly
Hi, I have an RAK3172 and I simple put a 1k resistor with LED to test my code. digitalwrite can blink the led but analogwrite can not why?
#define LED 21  //PB5 or WB_IO1
void setup() {
  // put your setup code here, to run once:
  pinMode(LED, OUTPUT);
void loop() {
  // put your main code here, to run repeatedly:
//not working there is no change on led
  for(int i = 0; i<255; i++){
    analogWrite(LED, i);
    delay(50);
// this is working and led blinking
  digitalWrite(LED, true);
  delay(1000);
  digitalWrite(LED, false);
  delay(1000);
somebody please help!
Tested on PA0 (I have no setup where I can use PB5 for PWM).
It works fine.
How is the LED connected to the pin?
My test code:
void loop()
	volatile int i = 0;
	for (i = 0; i < 255; i++)
		analogWrite(LED_GREEN, i);
		delay(10);
	// delay(100);
	for (i = 255; i >= 0; i--)
		delay(10);
	delay(500);
	// api.system.sleep.all();
	// api.system.scheduler.task.destroy();
no, not working
void setup() {
  pinMode(PB5, OUTPUT);
void loop()
	volatile int i = 0;
		analogWrite(PB5, i);
		delay(10);
	// delay(100);
		delay(10);
	delay(500);
this is only working with same condition:
void setup() {
void loop() {
  digitalWrite(PB5, 1);
  delay(2000);
  digitalWrite(PB5, 0);
  delay(2000);
this is simple board
