Application Node DR Distribution Stats not being updated
FW: 1.1.0053_Release r188
Im not seeing stats being updated for the Data Rate Distribution stats for individual nodes, the other stats are being updated, i…e pack distributions etc
I forgot to mention I found what was causing this, I had enabled ADR and selected DR6 as the max data rate, I re-configured to DR5 and viola the DR Distribution stats started updating again.
What is the best practice in-regard to the max ADR data rate setting?
Hi, you can find almost everything about SF, DR, etc. here :https://lora-alliance.org/sites/default/files/2018-04/lorawantm_regional_parameters_v1.1rb_-_final.pdf
