The datasheet for the RAK12032 3-Axis Accelerometer states
The RAK12032 module can be mounted on the slots: C, D, E, & F.
Whereas your other 3-Axis Accelerometer, the RAK1904 has exactly the same pinout (same interrupts map to the same GPIOs) yet it can be mounted on slots A-F.
Why the difference?
Obviously I’m hoping I can indeed use slots A or B with the RAK12032 to avoid conflicts.
I have another device which is unfortunately powered by V3V_S, however it should be always on. Is it possible to cut a trace somewhere on the Base (RAK19001) so that the power gating on V3V_S is disabled?
Yep, only one of them for now. The problem is the number of other sensors/IOs I have attached! I was already looking at cutting features to fit within the GPIO budget before you reminded me about IO2 (and on closer inspection, the datasheet does actually mention it - apologies)
