Arduino and RAK4631
Hello. I am having an issue when uploading my firmware to the RAK4631. This happens with both Arduino and the arduino-cli
arduino-cli upload -p /dev/ttyACM0 --fqbn rak_rui:nrf52:WisCoreRAK4631Board ../watermark_reader/
2023-03-10 14:35:24,877 Using board at serial port: /dev/ttyACM0
2023-03-10 14:35:24,879 Sending Application image.
2023-03-10 14:35:28,448 LIBUSB_ERROR_ACCESS: Unable to connect to trigger interface.
2023-03-10 14:35:28,449 Serial: Waiting 500 ms for device to enter bootloader 1/10 time
2023-03-10 14:35:28,976 Serial: Waiting 500 ms for device to enter bootloader 2/10 time
2023-03-10 14:35:29,515 Serial: Waiting 500 ms for device to enter bootloader 3/10 time
2023-03-10 14:35:30,034 Serial: Waiting 500 ms for device to enter bootloader 4/10 time
2023-03-10 14:35:30,570 Serial: Waiting 500 ms for device to enter bootloader 5/10 time
2023-03-10 14:35:31,109 Serial: Waiting 500 ms for device to enter bootloader 6/10 time
2023-03-10 14:35:31,646 Serial: Waiting 500 ms for device to enter bootloader 7/10 time
2023-03-10 14:35:32,172 Serial: Waiting 500 ms for device to enter bootloader 8/10 time
2023-03-10 14:35:32,709 Serial: Waiting 500 ms for device to enter bootloader 9/10 time
2023-03-10 14:35:33,253 Serial: Waiting 500 ms for device to enter bootloader 10/10 time
2023-03-10 14:35:33,789 Serial: Device is either not in bootloader mode, or using an unsupported bootloader.
2023-03-10 14:35:34,792 Serial: No ping response
2023-03-10 14:35:35,794 Serial: No ping response
2023-03-10 14:35:36,796 Serial: No ping response
2023-03-10 14:35:37,798 Serial: No ping response
2023-03-10 14:35:38,801 Serial: No ping response
I Thought maybe it was a Linux issue so I tried on windows and got a similar error.
I checked the bootloader and it also looks correct:
UF2 Bootloader 0.4.2 lib/nrfx (v2.0.0) lib/tinyusb (0.10.1-293-gaf8e5a90) lib/uf2 (remotes/origin/configupdate-9-gadbb8c7)
Model: WisBlock RAK4631 Board
Date: Dec  1 2021
SoftDevice: S140 6.1.1
Finally, I tried uploading firmware on windows, but had a similar error with triggering:
[------------------------------------]    0%2023-03-10 15:45:13,740 No trigger interface found for device with serial number: 24D743BAC5216B58, Product ID: 0x8029 and Vendor ID: 0x239A
I also tried jumping TX1 to ground to manually trigger DFU mode but no luck.
I’m a bit stumped at the moment, has anyone else had this problem?
Ah I see my mistake.
The bootloader was incorrect!
I made sure to engage DFU mode and then was able to reprogram. The LEDs changed from the blue and green blinking on the WisBlock Core to Just the red LED flashing intermittently.
I then uploaded the firmware as well and I can now program!
Caio
