What product do you wish to discuss? RAK3112
What firmware are you using? Arduino BSP
Computer OS? MacOS ver 13.7
How often does the problem happen?
Always. I can’t get it to compile using the RAKwireless-Audio libraries -
How can we replicate the problem?
I updated the libraries for the official ESP32 boards to select the RAK3112 board. When I try to compile with the Arduino IDE 1.8, I get an error saying it can’t find the “PDM.h” library.
I can compile if I select the WisCore RAK11200 board.
- Provide source code if custom firmware is used or link to example if RAKwireless example code is used.
Example Code:
#include “audio.h”
int channels = 1; //1 mono 2 stereo
// default PCM output frequency
static const int frequency = 16000;
// buffer to read samples into, each sample is 16-bits
short sampleBuffer[BUFFER_SIZE];
void setup() {
pinMode(WB_IO2, OUTPUT);
digitalWrite(WB_IO2, HIGH);
delay(500);
pinMode(LED_GREEN, OUTPUT);
digitalWrite(LED_GREEN, HIGH);
time_t timeout = millis();
while (!Serial)
if ((millis() - timeout) < 3000)
delay(100);
else
break;
// initialize PDM with:
// - one channel (mono mode)
// - a 16 kHz sample rate
if (!PDM.begin(channels, frequency)) {
Serial.println(“Failed to start PDM!”);
while (1) yield();
Serial.println(“=====================================”);
Serial.println(“PDM test”);
pinMode(LED_BLUE, OUTPUT);
digitalWrite(LED_BLUE, HIGH);
void loop() {
// Read data from microphone
int sampleRead = PDM.read(sampleBuffer, sizeof(sampleBuffer));
sampleRead = sampleRead / 2; //Each short data contains two Bytes
// wait for samples to be read
if (sampleRead > 0) {
// print samples to the serial monitor or plotter
for (int i = 0; i < sampleRead; i++) {
if (channels == 2)
Serial.print(“L:”);
Serial.print(sampleBuffer[i]);
Serial.print(" R:");
i++;
Serial.println(sampleBuffer[i]);
sampleRead = 0;
Error received:
In file included from /Users/rmunizr/Documents/Arduino/libraries/RAKwireless-Audio-library-main/examples/RAK11200/PDMSerialPlotter/PDMSerialPlotter.ino:13:
/Users/rmunizr/Documents/Arduino/libraries/RAKwireless-Audio-library-main/src/audio.h:7:10: fatal error: PDM.h: No such file or directory
7 | #include <PDM.h>
compilation terminated.
exit status 1
Error compilando para la tarjeta RAKwireless RAK3112.
I’m working on developing an audio analyzer for industrial applications using FFT, DSP, and various microphones. I decided to use the ESP32 S3 for its Edge AI capabilities, but now I see that I can’t use Rak Wireless’ official audio libraries for that SoC.
Any help to continue development?
