Hi, I have been having some trouble lately using an SD card together with a LoRa radio in Zephyr in a custom board based on the RAK4630, toolchain v3.2.0 from Nordic and SDK also v3.2.0 (Zephyr 4.2.99). I am using separate SPI instances for LoRa and the SD card (SPI1 and SPI2). However, when I initialize the SD card and enable backend logging to it, neither LoRa works properly nor are the logs correctly stored on the SD card (I also tried a few methods to prevent this such as disabling momentarely the backend, log flush and so one).
I have tried multiple approaches to make it work, but my main question is whether there is any incompatibility between them or if this is simply a firmware issue.
Here is my code:
main.c:
#include <zephyr/device.h>
#include <zephyr/kernel.h>
#include <zephyr/lorawan/lorawan.h>
#include <zephyr/logging/log.h>
#include <zephyr/sys/reboot.h>
#include <string.h>
#include "settings.h"
#include <zephyr/storage/disk_access.h>
#include <zephyr/fs/fs.h>
#include <ff.h>
LOG_MODULE_REGISTER(MAIN_, CONFIG_LOG_DEFAULT_LEVEL);
#define LORA_MSG_MAX_SIZE 32
#define LORA_MSG_QUEUE_LEN 5
K_MSGQ_DEFINE(lora_msgq, LORA_MSG_MAX_SIZE, LORA_MSG_QUEUE_LEN, 4);
K_SEM_DEFINE(lora_start_sem, 0, 1);
static void dl_callback(uint8_t port, uint8_t flags, int16_t rssi, int8_t snr, uint8_t len, const uint8_t *hex_data) {
LOG_INF("Port %d, Pending %d, RSSI %ddB, SNR %ddBm, Time %d", port, flags & LORAWAN_DATA_PENDING, rssi, snr, !!(flags & LORAWAN_TIME_UPDATED));
if (hex_data && len > 0) {
LOG_HEXDUMP_INF(hex_data, len, "Payload:");
static void lorawan_datarate_changed(enum lorawan_datarate dr) {
uint8_t unused, max_size;
lorawan_get_payload_sizes(&unused, &max_size);
LOG_INF("New Datarate: DR_%d | Max Payload: %d", dr, max_size);
void lora_thread(void) {
const struct device *lora_dev;
struct lorawan_join_config join_cfg;
struct lorawan_downlink_cb downlink_cb;
uint8_t dev_eui[] = LORAWAN_DEV_EUI;
uint8_t join_eui[] = LORAWAN_JOIN_EUI;
uint8_t app_key[] = LORAWAN_APP_KEY;
uint8_t tx_buf[LORA_MSG_MAX_SIZE];
int ret;
k_sem_take(&lora_start_sem, K_FOREVER);
LOG_INF("LoRaWAN thread starting");
lora_dev = DEVICE_DT_GET(DT_ALIAS(lora0));
if (!device_is_ready(lora_dev)) {
LOG_ERR("LoRa device not ready");
return;
ret = lorawan_start();
if (ret < 0) {
LOG_ERR("lorawan_start failed: %d", ret);
return;
downlink_cb.port = LW_RECV_PORT_ANY;
downlink_cb.cb = dl_callback;
lorawan_register_downlink_callback(&downlink_cb);
lorawan_register_dr_changed_callback(lorawan_datarate_changed);
join_cfg.mode = LORAWAN_ACT_OTAA;
join_cfg.dev_eui = dev_eui;
join_cfg.otaa.join_eui = join_eui;
join_cfg.otaa.app_key = app_key;
join_cfg.otaa.nwk_key = app_key;
uint8_t tries = 0;
while (tries++ < 5) {
LOG_INF("Joining network via OTAA");
if (!lorawan_join(&join_cfg)) {
LOG_INF("Successfully joined network");
goto JOINED;
LOG_ERR("Failed to join. Retrying in 10 seconds...");
k_sleep(K_SECONDS(10));
LOG_ERR("Failed to join network after %d attempts. Reseting board...", 5);
k_sleep(K_SECONDS(2));
sys_reboot(SYS_REBOOT_COLD);
return;
while (true) {
k_msgq_get(&lora_msgq, tx_buf, K_FOREVER);
ret = lorawan_send(2, tx_buf, strlen((char *)tx_buf), LORAWAN_MSG_CONFIRMED);
if (ret < 0) {
LOG_ERR("lorawan_send failed: %d", ret);
else {
LOG_INF("Data sent");
K_THREAD_DEFINE(lora_tid, 8192, lora_thread, NULL, NULL, NULL, 1, 0, 0);
FATFS fatfs;
#define MOUNT_POINT "/SD:"
static struct fs_mount_t fatfs_mnt = {
.type = FS_FATFS,
.mnt_point = MOUNT_POINT,
.fs_data = &fatfs,
int main(void) {
static const char *disk_pdrv = "SD";
uint64_t memory_size_mb;
uint32_t block_count;
uint32_t block_size;
char msg[] = "helloworld";
k_sleep(K_SECONDS(5));
LOG_INF("Main started");
if (disk_access_init(disk_pdrv) != 0) {
LOG_ERR("Storage init Error!");
return -1;
if (disk_access_ioctl(disk_pdrv, DISK_IOCTL_GET_SECTOR_COUNT, &block_count)) {
LOG_ERR("Unable to get sector count");
return -1;
if (disk_access_ioctl(disk_pdrv, DISK_IOCTL_GET_SECTOR_SIZE, &block_size)) {
LOG_ERR("Unable to get sector size");
return -1;
memory_size_mb = (uint64_t)block_count * block_size;
LOG_INF("Memory Size %uMB", (uint32_t)(memory_size_mb >> 20));
if (fs_mount(&fatfs_mnt) == FR_OK) {
LOG_INF("SD Card mounted");
} else {
LOG_ERR("Error mounting SD Card");
k_sem_give(&lora_start_sem);
while (true) {
if (k_msgq_put(&lora_msgq, msg, K_NO_WAIT) != 0) {
LOG_WRN("MSGQ full, dropping message");
else {
LOG_INF("Message queued");
k_sleep(K_SECONDS(20));
proj.conf
CONFIG_LOG=y
CONFIG_LORA=y
CONFIG_LORAWAN=y
CONFIG_LORAMAC_REGION_EU868=y
CONFIG_MAIN_STACK_SIZE=4096
CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=4096
CONFIG_REBOOT=y
# NVS
CONFIG_NVS=y
CONFIG_FLASH=y
CONFIG_FLASH_MAP=y
CONFIG_FLASH_PAGE_LAYOUT=y
# SD Card
CONFIG_DISK_ACCESS=y
CONFIG_FILE_SYSTEM=y
CONFIG_FAT_FILESYSTEM_ELM=y
CONFIG_LOG_BACKEND_FS=y
CONFIG_LOG_BACKEND_FS_OUTPUT_TEXT=y
CONFIG_LOG_BACKEND_FS_DIR="/SD:"
CONFIG_LOG_BACKEND_FS_FILE_PREFIX="log"
CONFIG_LOG_BACKEND_FS_FILES_LIMIT=100
CONFIG_LOG_BACKEND_FS_FILE_SIZE=131072
CONFIG_LOG_BACKEND_FS_OVERWRITE=y
dts for custom board:
/dts-v1/;
#include <nordic/nrf52840_qiaa.dtsi>
#include <nordic/nrf52840_partition.dtsi>
#include "esav01_nrf52840-pinctrl.dtsi"
#include <zephyr/dt-bindings/lora/sx126x.h>
model = "Board 1";
compatible = "nordic,esav01_nrf52840";
chosen {
zephyr,console = &uart1;
zephyr,shell-uart = &uart1;
zephyr,uart-mcumgr = &uart1;
zephyr,bt-mon-uart = &uart1;
zephyr,bt-c2h-uart = &uart1;
aliases {
lora0 = &lora;
®0 {
status = "okay";
®1 {
regulator-initial-mode = <NRF5X_REG_MODE_DCDC>;
&uicr {
gpio-as-nreset;
nfct-pins-as-gpios;
&gpiote {
status = "okay";
&gpio0 {
status = "okay";
&gpio1 {
status = "okay";
&uart1 {
compatible = "nordic,nrf-uarte";
status = "okay";
current-speed = <115200>;
pinctrl-0 = <&uart1_default>;
pinctrl-1 = <&uart1_sleep>;
pinctrl-names = "default", "sleep";
&i2c1 {
status = "disabled";
&spi0 {
&spi1 {
compatible = "nordic,nrf-spim";
status = "okay";
cs-gpios = <&gpio1 10 GPIO_ACTIVE_LOW>;
pinctrl-0 = <&spi1_default>;
pinctrl-1 = <&spi1_sleep>;
lora: lora@0 {
compatible = "semtech,sx1262";
reg = <0>;
reset-gpios = <&gpio1 6 GPIO_ACTIVE_LOW>;
busy-gpios = <&gpio1 14 GPIO_ACTIVE_HIGH>;
dio1-gpios = <&gpio1 15 GPIO_ACTIVE_HIGH>;
dio2-tx-enable;
dio3-tcxo-voltage = <SX126X_DIO3_TCXO_3V3>;
tcxo-power-startup-delay-ms = <5>;
spi-max-frequency = <1000000>;
&spi2 {
status = "okay";
cs-gpios = <&gpio0 26 GPIO_ACTIVE_LOW>;
pinctrl-0 = <&spi2_default>;
pinctrl-1 = <&spi2_sleep>;
sdhc0: sdhc@0 {
compatible = "zephyr,sdhc-spi-slot";
reg = <0>;
status = "okay";
mmc {
compatible = "zephyr,sdmmc-disk";
disk-name = "SD";
status = "okay";
spi-max-frequency = <25000000>;
&qspi {
Thank you for your help.
