Basic station rak 2287 usb
I have a RAK 2287 USB that connects via UDP packet forwarder to TTN, but the end devices are not joining. When I switch to Basic Station, I get an issue related to certificates. Does anyone know what’s happening? I’m using Balena OS.
basicstation 2024-10-04 05:15:56.205 [AIO:INFO] ./tc.trust:
basicstation cert. version : 3
basicstation serial number : 04:00:00:00:00:01:15:4B:5A:C3:94
basicstation issuer name : C=BE, O=GlobalSign nv-sa, OU=Root CA, CN=GlobalSign Root CA
basicstation subject name : C=BE, O=GlobalSign nv-sa, OU=Root CA, CN=GlobalSign Root CA
basicstation issued on : 1998-09-01 12:00:00
basicstation expires on : 2028-01-28 12:00:00
basicstation signed using : RSA with SHA1
basicstation RSA key size : 2048 bits
basicstation basic constraints : CA=true
basicstation key usage : Key Cert Sign, CRL Sign
basicstation 2024-10-04 05:15:56.205 [TCE:INFO] Connecting to INFOS: wss://localhost:8887
basicstation 2024-10-04 05:15:56.221 [AIO:INFO] TLS server certificate verification failed: The certificate is not correctly signed by the trusted CA
basicstation 2024-10-04 05:15:56.221 [AIO:DEBU] [4] WS connection shutdown…
basicstation 2024-10-04 05:15:56.222 [TCE:INFO] INFOS reconnect backoff 60s (retry 50)
basicstation 2024-10-04 05:16:56.288 [AIO:INFO] ./tc.trust:
basicstation 2024-10-04 05:16:56.288 [TCE:INFO] Connecting to INFOS: wss://localhost:8887
basicstation 2024-10-04 05:16:56.306 [AIO:INFO] TLS server certificate verification failed: The certificate is not correctly signed by the trusted CA
basicstation 2024-10-04 05:16:56.306 [AIO:DEBU] [4] WS connection shutdown…
basicstation 2024-10-04 05:16:56.307 [TCE:INFO] INFOS reconnect backoff 60s (retry 51)
basicstation 2024-10-04 05:17:56.374 [AIO:INFO] ./tc.trust:
basicstation 2024-10-04 05:17:56.374 [TCE:INFO] Connecting to INFOS: wss://localhost:8887
basicstation 2024-10-04 05:17:56.390 [AIO:INFO] TLS server certificate verification failed: The certificate is not correctly signed by the trusted CA
basicstation 2024-10-04 05:17:56.390 [AIO:DEBU] [4] WS connection shutdown…
basicstation 2024-10-04 05:17:56.391 [TCE:INFO] INFOS reconnect backoff 60s (retry 52)
basicstation 2024-10-04 05:18:56.458 [AIO:INFO] ./tc.trust:
basicstation 2024-10-04 05:18:56.458 [TCE:INFO] Connecting to INFOS: wss://localhost:8887
basicstation 2024-10-04 05:18:56.473 [AIO:INFO] TLS server certificate verification failed: The certificate is not correctly signed by the trusted CA
basicstation 2024-10-04 05:18:56.473 [AIO:DEBU] [4] WS connection shutdown…
basicstation 2024-10-04 05:18:56.474 [TCE:INFO] INFOS reconnect backoff 60s (retry 53)
basicstation 2024-10-04 05:19:56.544 [AIO:INFO] ./tc.trust:
basicstation 2024-10-04 05:19:56.544 [TCE:INFO] Connecting to INFOS: wss://localhost:8887
basicstation 2024-10-04 05:19:56.560 [AIO:INFO] TLS server certificate verification failed: The certificate is not correctly signed by the trusted CA
basicstation 2024-10-04 05:19:56.560 [AIO:DEBU] [4] WS connection shutdown…
basicstation 2024-10-04 05:19:56.561 [TCE:INFO] INFOS reconnect backoff 60s (retry 54)
basicstation 2024-10-04 05:20:56.627 [AIO:INFO] ./tc.trust:
basicstation 2024-10-04 05:20:56.628 [TCE:INFO] Connecting to INFOS: wss://localhost:8887
basicstation 2024-10-04 05:20:56.643 [AIO:INFO] TLS server certificate verification failed: The certificate is not correctly signed by the trusted CA
basicstation 2024-10-04 05:20:56.643 [AIO:DEBU] [4] WS connection shutdown…
basicstation 2024-10-04 05:20:56.643 [TCE:INFO] INFOS reconnect backoff 60s (retry 55)
basicstation 2024-10-04 05:21:56.707 [AIO:INFO] ./tc.trust:
basicstation 2024-10-04 05:21:56.708 [TCE:INFO] Connecting to INFOS: wss://localhost:8887
basicstation 2024-10-04 05:21:56.723 [AIO:INFO] TLS server certificate verification failed: The certificate is not correctly signed by the trusted CA
basicstation 2024-10-04 05:21:56.723 [AIO:DEBU] [4] WS connection shutdown…
basicstation 2024-10-04 05:21:56.724 [TCE:INFO] INFOS reconnect backoff 60s (retry 56)
basicstation 2024-10-04 05:22:56.790 [AIO:INFO] ./tc.trust:
basicstation 2024-10-04 05:22:56.790 [TCE:INFO] Connecting to INFOS: wss://localhost:8887
basicstation 2024-10-04 05:22:56.806 [AIO:INFO] TLS server certificate verification failed: The certificate is not correctly signed by the trusted CA
basicstation 2024-10-04 05:22:56.806 [AIO:DEBU] [4] WS connection shutdown…
basicstation 2024-10-04 05:22:56.808 [TCE:INFO] INFOS reconnect backoff 60s (retry 57)
basicstation 2024-10-04 05:23:56.875 [AIO:INFO] ./tc.trust:
basicstation 2024-10-04 05:23:56.875 [TCE:INFO] Connecting to INFOS: wss://localhost:8887
basicstation 2024-10-04 05:23:56.891 [AIO:INFO] TLS server certificate verification failed: The certificate is not correctly signed by the trusted CA
basicstation 2024-10-04 05:23:56.891 [AIO:DEBU] [4] WS connection shutdown…
basicstation 2024-10-04 05:23:56.892 [TCE:INFO] INFOS reconnect backoff 60s (retry 58)
basicstation 2024-10-04 05:24:56.958 [AIO:INFO] ./tc.trust:
basicstation 2024-10-04 05:24:56.958 [TCE:INFO] Connecting to INFOS: wss://localhost:8887
basicstation 2024-10-04 05:24:56.973 [AIO:INFO] TLS server certificate verification failed: The certificate is not correctly signed by the trusted CA
basicstation 2024-10-04 05:24:56.973 [AIO:DEBU] [4] WS connection shutdown…
basicstation 2024-10-04 05:24:56.974 [TCE:INFO] INFOS reconnect backoff 60s (retry 59)
basicstation 2024-10-04 05:25:57.041 [AIO:INFO] ./tc.trust:
basicstation 2024-10-04 05:25:57.041 [TCE:INFO] Connecting to INFOS: wss://localhost:8887
basicstation 2024-10-04 05:25:57.055 [AIO:INFO] TLS server certificate verification failed: The certificate is not correctly signed by the trusted CA
basicstation 2024-10-04 05:25:57.055 [AIO:DEBU] [4] WS connection shutdown…
basicstation 2024-10-04 05:25:57.056 [TCE:INFO] INFOS reconnect backoff 60s (retry 60)
basicstation 2024-10-04 05:26:57.122 [AIO:INFO] ./tc.trust:
basicstation 2024-10-04 05:26:57.122 [TCE:INFO] Connecting to INFOS: wss://localhost:8887
basicstation 2024-10-04 05:26:57.139 [AIO:INFO] TLS server certificate verification failed: The certificate is not correctly signed by the trusted CA
basicstation 2024-10-04 05:26:57.139 [AIO:DEBU] [4] WS connection shutdown…
basicstation 2024-10-04 05:26:57.139 [TCE:INFO] INFOS reconnect backoff 60s (retry 61)
basicstation 2024-10-04 05:27:57.205 [AIO:INFO] ./tc.trust:
basicstation 2024-10-04 05:27:57.205 [TCE:INFO] Connecting to INFOS: wss://localhost:8887
basicstation 2024-10-04 05:27:57.220 [AIO:INFO] TLS server certificate verification failed: The certificate is not correctly signed by the trusted CA
basicstation 2024-10-04 05:27:57.220 [AIO:DEBU] [4] WS connection shutdown…
basicstation 2024-10-04 05:27:57.221 [TCE:INFO] INFOS reconnect backoff 60s (retry 62)
basicstation 2024-10-04 05:28:57.286 [AIO:INFO] ./tc.trust:
basicstation 2024-10-04 05:28:57.287 [TCE:INFO] Connecting to INFOS: wss://localhost:8887
basicstation 2024-10-04 05:28:57.301 [AIO:INFO] TLS server certificate verification failed: The certificate is not correctly signed by the trusted CA
basicstation 2024-10-04 05:28:57.301 [AIO:DEBU] [4] WS connection shutdown…
basicstation 2024-10-04 05:28:57.302 [TCE:INFO] INFOS reconnect backoff 60s (retry 63)
