I’m using a RAK2287 with a RPi4 along with BasicStation to create a gateway device to deliver sensor data through to AWS IoTCore with CUPS authentication.
After starting my gateway it seems as if things are going well, but after a few minutes I get a number of ‘time sync rejected’ messages and sometimes some Repeated excessive clock drifts between MCU/SX130X#0 messages before the station disconnects and restarts.
What does this mean, and what could cause it? Logs below.
2021-10-08 12:55:48.920 [SYS:INFO] Logging : stderr (maxsize=10000000, rotate=3)
2021-10-08 12:55:48.920 [SYS:INFO] Station Ver : 2.0.5(corecell/std) 2021-10-05 15:02:16
2021-10-08 12:55:48.921 [SYS:INFO] Package Ver : (null)
2021-10-08 12:55:48.921 [SYS:INFO] proto EUI : 0:dca6:3205:f1a (/sys/class/net/eth0/address)
2021-10-08 12:55:48.921 [SYS:INFO] prefix EUI : ::1 (builtin)
2021-10-08 12:55:48.921 [SYS:INFO] Station EUI : dca6:32ff:fe05:f1a
2021-10-08 12:55:48.921 [SYS:INFO] Station home: ./ (builtin)
2021-10-08 12:55:48.921 [SYS:INFO] Station temp: /var/tmp/ (builtin)
2021-10-08 12:55:49.123 [TCE:INFO] Starting TC engine
2021-10-08 12:55:49.124 [any:INFO] ./tc.trust:
cert. version : 3
serial number : A7:0E:4A:4C:34:82:B7:7F
issuer name : C=US, O=Starfield Technologies, Inc., OU=Starfield Class 2 Certification Authority
subject name : C=US, ST=Arizona, L=Scottsdale, O=Starfield Technologies, Inc., CN=Starfield Services Root Certificate Authority - G2
issued on : 2009-09-02 00:00:00
expires on : 2034-06-28 17:39:16
signed using : RSA with SHA-256
RSA key size : 2048 bits
basic con2021-10-08 12:55:49.132 [any:INFO] ./tc.crt:
cert. version : 3
serial number : 70:B9:E0:68:0E:62:85:AC:A4:7F:0D:0C:81:3D:6D:06:D7:95:C0:AE
issuer name : OU=Amazon Web Services O=Amazon.com Inc. L=Seattle ST=Washington C=US
subject name : CN=AWS IoT Certificate
issued on : 2021-10-05 13:52:18
expires on : 2049-12-31 23:59:59
basic constraints : CA=false
key usage : Digital Signature
2021-10-08 12:55:49.132 [AIO:INFO]
2021-10-08 12:55:51.807 [TCE:INFO] Connecting to INFOS: wss://A3OQ74V8656RDU.lns.lorawan.us-west-2.amazonaws.com:443
2021-10-08 12:55:51.807 [CUP:INFO] Starting a CUPS session in 0 seconds.
2021-10-08 12:55:51.807 [CUP:INFO] Starting a CUPS session now.
2021-10-08 12:55:51.807 [CUP:INFO] Connecting to CUPS ... https://A3OQ74V8656RDU.cups.lorawan.us-west-2.amazonaws.com:443 (try #1)
2021-10-08 12:55:51.808 [any:INFO] ./cups.trust:
cert. version : 3
basic c2021-10-08 12:55:51.816 [any:INFO] ./cups.crt:
cert. version : 3
serial number : 2F:B2:92:89:7F:3C:5C:D7:89:CB:36:E6:5A:1B:82:93:A7:9D:AF:B6
issued on : 2021-09-27 10:25:44
2021-10-08 12:55:51.816 [AIO:INFO]
2021-10-08 12:55:51.928 [CUP:VERB] Retrieving update-info from CUPS https://A3OQ74V8656RDU.cups.lorawan.us-west-2.amazonaws.com:443...
2021-10-08 12:55:53.746 [AIO:DEBU] [4] HTTP connection shutdown...
2021-10-08 12:55:53.746 [CUP:INFO] Interaction with CUPS done (no updates) - next regular check in 1d
2021-10-08 12:55:53.832 [TCE:INFO] Infos: dca6:32ff:fe05:0f1a dca6:32ff:fe05:0f1a wss://A3OQ74V8656RDU.lns.lorawan.us-west-2.amazonaws.com:443/gateway/dca632fffe050f1a
2021-10-08 12:55:53.832 [AIO:DEBU] [3] ws_close reason=1000
2021-10-08 12:55:53.832 [AIO:DEBU] [3|WS] Server sent close: reason=1006
2021-10-08 12:55:53.832 [AIO:DEBU] [3] WS connection shutdown...
2021-10-08 12:55:53.832 [any:INFO] ./tc.trust:
cert. version : 3
basic con2021-10-08 12:55:53.835 [any:INFO] ./tc.crt:
cert. version : 3
2021-10-08 12:55:53.835 [AIO:INFO]
2021-10-08 12:55:53.878 [TCE:VERB] Connecting to MUXS...
2021-10-08 12:55:54.964 [TCE:VERB] Connected to MUXS.
2021-10-08 12:55:55.169 [S2E:WARN] Unknown field in router_config - ignored: protocol (0xFD309030)
2021-10-08 12:55:55.169 [S2E:WARN] Unknown field in router_config - ignored: regionid (0xE6FFB211)
2021-10-08 12:55:55.171 [SYS:VERB] rinit.sh: Forked, waiting...
CoreCell reset through GPIO17...
CoreCell power enable through GPIO18...
2021-10-08 12:55:56.140 [SYS:INFO] Process rinit.sh (pid=886) completed
ERROR: Failed to stop TX trigger
ERROR: failed to close I2C device (err=-1)
2021-10-08 12:55:56.140 [RAL:INFO] Lora gateway library version: Version: 1.0.5;
2021-10-08 12:55:56.146 [RAL:VERB] Connecting to device: /dev/spidev0.0
2021-10-08 12:55:56.146 [RAL:DEBU] SX130x txlut table (16 entries)
2021-10-08 12:55:56.146 [RAL:VERB] SX1302 txlut 0: rf_power=12 pa_gain=0 pwr_idx=15
2021-10-08 12:55:56.146 [RAL:VERB] SX1302 txlut 1: rf_power=13 pa_gain=0 pwr_idx=16
2021-10-08 12:55:56.146 [RAL:VERB] SX1302 txlut 2: rf_power=14 pa_gain=0 pwr_idx=17
2021-10-08 12:55:56.146 [RAL:VERB] SX1302 txlut 3: rf_power=15 pa_gain=0 pwr_idx=19
2021-10-08 12:55:56.146 [RAL:VERB] SX1302 txlut 4: rf_power=16 pa_gain=0 pwr_idx=20
2021-10-08 12:55:56.146 [RAL:VERB] SX1302 txlut 5: rf_power=17 pa_gain=0 pwr_idx=22
2021-10-08 12:55:56.146 [RAL:VERB] SX1302 txlut 6: rf_power=18 pa_gain=1 pwr_idx=1
2021-10-08 12:55:56.146 [RAL:VERB] SX1302 txlut 7: rf_power=19 pa_gain=1 pwr_idx=2
2021-10-08 12:55:56.146 [RAL:VERB] SX1302 txlut 8: rf_power=20 pa_gain=1 pwr_idx=3
2021-10-08 12:55:56.146 [RAL:VERB] SX1302 txlut 9: rf_power=21 pa_gain=1 pwr_idx=4
2021-10-08 12:55:56.146 [RAL:VERB] SX1302 txlut 10: rf_power=22 pa_gain=1 pwr_idx=5
2021-10-08 12:55:56.146 [RAL:VERB] SX1302 txlut 11: rf_power=23 pa_gain=1 pwr_idx=6
2021-10-08 12:55:56.146 [RAL:VERB] SX1302 txlut 12: rf_power=24 pa_gain=1 pwr_idx=7
2021-10-08 12:55:56.146 [RAL:VERB] SX1302 txlut 13: rf_power=25 pa_gain=1 pwr_idx=9
2021-10-08 12:55:56.146 [RAL:VERB] SX1302 txlut 14: rf_power=26 pa_gain=1 pwr_idx=11
2021-10-08 12:55:56.146 [RAL:VERB] SX1302 txlut 15: rf_power=27 pa_gain=1 pwr_idx=14
2021-10-08 12:55:56.146 [RAL:VERB] SX1302 rssi_tcomp: coeff_a=0.000 coeff_b=0.000 coeff_c=20.410 coeff_d=2162.560 coeff_e=0.000
2021-10-08 12:55:56.146 [RAL:VERB] SX1302 rxrfchain 0: enable=1 freq=867.5MHz rssi_offset=-215.399994 type=5 tx_enable=1
2021-10-08 12:55:56.146 [RAL:VERB] SX1302 rxrfchain 1: enable=1 freq=868.5MHz rssi_offset=-215.399994 type=5 tx_enable=0
2021-10-08 12:55:56.146 [RAL:VERB] SX1302 ifchain 0: enable=1 rf_chain=0 freq=-400000 bw=0 SF=0 sync_word=0/0
2021-10-08 12:55:56.146 [RAL:VERB] SX1302 ifchain 1: enable=1 rf_chain=0 freq=-200000 bw=0 SF=0 sync_word=0/0
2021-10-08 12:55:56.146 [RAL:VERB] SX1302 ifchain 2: enable=1 rf_chain=0 freq=0 bw=0 SF=0 sync_word=0/0
2021-10-08 12:55:56.146 [RAL:VERB] SX1302 ifchain 3: enable=1 rf_chain=0 freq=200000 bw=0 SF=0 sync_word=0/0
2021-10-08 12:55:56.146 [RAL:VERB] SX1302 ifchain 4: enable=1 rf_chain=0 freq=400000 bw=0 SF=0 sync_word=0/0
2021-10-08 12:55:56.146 [RAL:VERB] SX1302 ifchain 5: enable=1 rf_chain=1 freq=-400000 bw=0 SF=0 sync_word=0/0
2021-10-08 12:55:56.146 [RAL:VERB] SX1302 ifchain 6: enable=1 rf_chain=1 freq=-200000 bw=0 SF=0 sync_word=0/0
2021-10-08 12:55:56.146 [RAL:VERB] SX1302 ifchain 7: enable=1 rf_chain=1 freq=0 bw=0 SF=0 sync_word=0/0
2021-10-08 12:55:56.146 [RAL:VERB] SX1302 ifchain 8: enable=1 rf_chain=1 freq=-200000 bw=5 SF=7 sync_word=0/0 [STD] Explicit header
2021-10-08 12:55:56.146 [RAL:VERB] SX1302 ifchain 9: enable=1 rf_chain=0 freq=0 bw=0 SF=0 sync_word=0/0
2021-10-08 12:55:56.146 [RAL:VERB] Station device: /dev/spidev0.0 (PPS capture disabled)
2021-10-08 12:55:58.575 [RAL:VERB] Concentrator started (2s428ms)
2021-10-08 12:55:58.575 [S2E:INFO] Configuring for region: EU868 -- 863.0MHz..870.0MHz
2021-10-08 12:55:58.575 [S2E:VERB] DR0 SF12/BW125
2021-10-08 12:55:58.575 [S2E:VERB] DR1 SF11/BW125
2021-10-08 12:55:58.575 [S2E:VERB] DR2 SF10/BW125
2021-10-08 12:55:58.575 [S2E:VERB] DR3 SF9/BW125
2021-10-08 12:55:58.575 [S2E:VERB] DR4 SF8/BW125
2021-10-08 12:55:58.575 [S2E:VERB] DR5 SF7/BW125
2021-10-08 12:55:58.575 [S2E:VERB] DR6 SF7/BW250
2021-10-08 12:55:58.575 [S2E:VERB] DR7 FSK
2021-10-08 12:55:58.575 [S2E:VERB] DR8 undefined
2021-10-08 12:55:58.575 [S2E:VERB] DR9 undefined
2021-10-08 12:55:58.575 [S2E:VERB] DR10 undefined
2021-10-08 12:55:58.575 [S2E:VERB] DR11 undefined
2021-10-08 12:55:58.575 [S2E:VERB] DR12 undefined
2021-10-08 12:55:58.575 [S2E:VERB] DR13 undefined
2021-10-08 12:55:58.575 [S2E:VERB] DR14 undefined
2021-10-08 12:55:58.575 [S2E:VERB] DR15 undefined
2021-10-08 12:55:58.575 [S2E:VERB] TX power: 0.0 dBm EIRP
2021-10-08 12:55:58.575 [S2E:VERB] JoinEUI list: 0 entries
2021-10-08 12:55:58.575 [S2E:VERB] NetID filter: FFFFFFFF-FFFFFFFF-FFFFFFFF-FFFFFFFF
2021-10-08 12:55:58.575 [S2E:VERB] Dev/test settings: nocca=0 nodc=0 nodwell=0
2021-10-08 12:56:25.206 [S2E:VERB] RX 867.5MHz DR0 SF12/BW125 snr=-19.2 rssi=-114 xtime=0xB0000001A2303B - updf mhdr=40 DevAddr=0100DA30 FCtrl=D8 FCnt=21758 FOpts=[BD0069F0009E437B] 8E8D31E6..0626 mic=1125777498 (52 bytes)
2021-10-08 12:56:40.586 [SYN:INFO] MCU/SX130X drift stats: min: +27.1ppm q50: +30.9ppm q80: +33.3ppm max: +34.3ppm - threshold q90: +34.3ppm
2021-10-08 12:56:40.586 [SYN:INFO] Mean MCU drift vs SX130X#0: 30.8ppm
2021-10-08 12:56:59.489 [SYN:INFO] Time sync qualities: min=185 q90=213 max=213 (previous q90=2147483647)
2021-10-08 12:57:22.599 [SYN:VERB] Time sync rejected: quality=6398 threshold=213
2021-10-08 12:57:24.699 [SYN:INFO] MCU/SX130X drift stats: min: +22.4ppm q50: +26.2ppm q80: +29.0ppm max: +30.5ppm - threshold q90: +30.4ppm
2021-10-08 12:57:24.699 [SYN:INFO] Mean MCU drift vs SX130X#0: 26.3ppm
2021-10-08 12:57:45.705 [SYN:VERB] Time sync rejected: quality=3486 threshold=213
2021-10-08 12:58:02.508 [SYN:INFO] Time sync qualities: min=188 q90=213 max=6398 (previous q90=213)
2021-10-08 12:58:08.811 [SYN:INFO] MCU/SX130X drift stats: min: +16.2ppm q50: +22.4ppm q80: +23.8ppm max: +26.2ppm - threshold q90: +26.2ppm
2021-10-08 12:58:08.811 [SYN:INFO] Mean MCU drift vs SX130X#0: 22.1ppm
2021-10-08 12:58:40.320 [SYN:VERB] Time sync rejected: quality=6319 threshold=213
2021-10-08 12:58:52.922 [SYN:INFO] MCU/SX130X drift stats: min: +12.4ppm q50: +19.0ppm q80: +20.5ppm max: +22.4ppm - threshold q90: +21.4ppm
2021-10-08 12:58:52.922 [SYN:INFO] Mean MCU drift vs SX130X#0: 18.7ppm
2021-10-08 12:59:05.523 [SYN:INFO] Time sync qualities: min=185 q90=212 max=6319 (previous q90=213)
2021-10-08 12:59:20.229 [SYN:VERB] Time sync rejected: quality=3559 threshold=212
2021-10-08 12:59:25.586 [AIO:DEBU] [3] Connection closed unexpectedly
2021-10-08 12:59:25.586 [AIO:DEBU] [3] WS connection shutdown...
2021-10-08 12:59:25.587 [TCE:VERB] Connection to MUXS closed in state 4
2021-10-08 12:59:25.587 [TCE:INFO] MUXS reconnect backoff 1s (retry 0)
