Hi Nikola,
Something I forgot to mention is that the decoding works fine for 3.65V and up from there.
I’m using Proximus Mythings, which I assume is what you mean by lns.
I’m not entirely certain which settings you are require, but I hope this works:
Region: EU868
Send_interval: 300s
Auto send status: true
Send_interval work at sleep
MulticastEnable: false
DutycycleEnable: false
Send_repeat_cnt: 0
Join_mode: OTAA
Class: A
Joined Network:false
IsConfirm: unconfirm
AdrEnable: true
EnableRepeaterSupport: false
RX2_CHANNEL_FREQUENCY: 869525000, RX2_CHANNEL_DR:0
RX_WINDOW_DURATION: 3000ms
RECEIVE_DELAY_1: 1000ms
RECEIVE_DELAY_2: 2000ms
JOIN_ACCEPT_DELAY_1: 5000ms
JOIN_ACCEPT_DELAY_2: 6000ms
Current Datarate: 3
Primeval Datarate: 3
ChannelsTxPower: 0
UpLinkCounter: 0
DownLinkCounter: 0
As for the decoder, I based myself on the decoder as specified on the github
while (Str.Length > 4)
string flag = Str.Substring(0, 4);
switch (flag)
case "0768": // Humidity
rakData.Humidity = (float)Math.Round(Convert.ToByte(Str.Substring(4, 2), 16) / 2 * 0.01 * 100, 1); // unit: %RH
Str = Str.Substring(6);
break;
case "0673": // Atmospheric pressure
rakData.Pressure = (float)Math.Round(Convert.ToUInt16(Str.Substring(4, 4),16)*0.1,2); // unit: hPa
Str = Str.Substring(8);
break;
case"0267": // Temperature
rakData.Temperature = (float)Math.Round(Convert.ToInt16(Str.Substring(4, 4), 16) * 0.1, 2); // unit: °C
break;
case "0188": // GPS
rakData.Latitude = (float)Math.Round(Convert.ToInt32(Str.Substring(4, 8), 16) * 0.000001, 6); // unit: °
rakData.Longitude = (float)Math.Round(Convert.ToInt32(Str.Substring(12, 8), 16) * 0.000001, 6); // unit: °
rakData.Altitude = (float)Math.Round(Convert.ToInt32(Str.Substring(20, 8), 16) * 0.01, 6); // unit: m
Str = Str.Substring(28);
break;
case "0371": // Triaxial acceleration
rakData.AccX = (float)Math.Round(Convert.ToInt16(Str.Substring(4, 4), 16) * 0.001, 3); // unit: g
rakData.AccY = (float)Math.Round(Convert.ToInt16(Str.Substring(8, 4), 16) * 0.001, 3); // unit: g
rakData.AccZ = (float)Math.Round(Convert.ToInt16(Str.Substring(12, 4), 16) * 0.001, 3); // unit: g
Str = Str.Substring(16);
break;
case "0402": // air resistance
rakData.GasResistance = (float)Math.Round(Convert.ToInt16(Str.Substring(4, 4), 16) * 0.01, 2); // unit: KΩ
break;
case "0802": // Battery Voltage
rakData.Battery = (float)Math.Round(Convert.ToInt16(Str.Substring(4, 4), 16) * 0.01, 2); // unit: V
break;
case "0586": // gyroscope // currently not used
rakData.GyroX = (float)Math.Round(Convert.ToInt16(Str.Substring(4, 4), 16) * 0.01, 2); // unit: °/s
rakData.GyroY = (float)Math.Round(Convert.ToInt16(Str.Substring(8, 4), 16) * 0.01, 2); // unit: °/s
rakData.GyroZ = (float)Math.Round(Convert.ToInt16(Str.Substring(12, 4), 16) * 0.01, 2); // unit: °/s
break;
case "0902": // magnetometer x // currently not used
rakData.MagnetometerX = (float)Math.Round(Convert.ToInt16(Str.Substring(4, 4), 16) * 0.01, 2); // unit: μT
break;
case "0a02": // magnetometer y // currently not used
rakData.MagnetometerY = (float)Math.Round(Convert.ToInt16(Str.Substring(4, 4), 16) * 0.01, 2); // unit: μT
break;
case "0b02": // magnetometer z // currently not used
rakData.MagnetometerZ = (float)Math.Round(Convert.ToInt16(Str.Substring(4, 4), 16) * 0.01, 2); // unit: μT
break;
default:
Str = Str.Substring(7);
break;
