Hello, I want to make the BLE state work for a certain period of time. BLE is activated when I throw a certain char. I wanted to add a period to the code with the millis() command. However, it does not enter the Period. Could you please provide a comment or advice?
#include <Arduino.h>
#include <bluefruit.h>
#include <Wire.h>
// // Forward declarations for functions
// void connect_callback(uint16_t conn_handle);
// void disconnect_callback(uint16_t conn_handle, uint8_t reason);
@brief BLE DFU service
@note Used for DFU OTA upgrade
BLEDfu bledfu;
@brief Arduino setup function. Called once after power on or reset
void setup()
// Initialize built in green LED
pinMode(LED_BUILTIN, OUTPUT);
// Wait for USB Serial to be ready or terminal to be connected
time_t timeout = millis(); // Timeout in case the system runs on its own
// Waiting for Serial
while (!Serial)
// Blink the LED to show that we are alive
delay(100);
digitalWrite(LED_BUILTIN, !digitalRead(LED_BUILTIN));
else
// Timeout while waiting for USB Serial
break;
void loop()
unsigned long previousTime = 0;
while (Serial.available() > 0)
if (Serial.read() == '1') {
if ((millis()-previousTime) < 50000UL)
Serial.printf("system is works");
Serial.println("================================");
Serial.println("RAK4631 BLE OTA example");
// Config the peripheral connection with maximum bandwidth more SRAM required by SoftDevice Note: All config***() function must be called before begin()
Bluefruit.configPrphBandwidth(BANDWIDTH_MAX);
Bluefruit.configPrphConn(92, BLE_GAP_EVENT_LENGTH_MIN, 16, 16);
Bluefruit.begin(1, 0);
// Set max power. Accepted values are: -40, -30, -20, -16, -12, -8, -4, 0, 4
Bluefruit.setTxPower(4);
// Set the BLE device name
Bluefruit.setName("RAK4631_OTA");
// Bluefruit.Periph.setConnectCallback(connect_callback);
// Bluefruit.Periph.setDisconnectCallback(disconnect_callback);
bledfu.begin();
Bluefruit.Advertising.addFlags(BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE);
Bluefruit.Advertising.addTxPower();
Bluefruit.Advertising.addName();
Bluefruit.Advertising.restartOnDisconnect(true);
Bluefruit.Advertising.setInterval(32, 244); // in unit of 0.625 ms
Bluefruit.Advertising.setFastTimeout(30); // number of seconds in fast mode
Bluefruit.Advertising.start(0); // 0 = Don't stop advertising after n seconds
