I would like to use the Bluetooth functionality of the Raspberry Pi Zero W which is part of the RAK 7246 gateway but it seems to be disabled. Even after enabling in the boot configuration it isn’t available. I fear that the ports are shared with the LoRa hat. Is there any chance to get Bluetooth working?
Remove the line "dtoverlay = disable-bt" from /boot/config.txt.
I’ve done that and rebooted afterwards. But no change.
root@rak-gateway:~# lsmod | grep bt
btbcm 16384 0
bluetooth 409600 8 bnep,btbcm
root@rak-gateway:~# lsmod | grep blu
ecdh_generic 28672 1 bluetooth
rfkill 28672 6 bluetooth,cfg80211
root@rak-gateway:~# dmesg | grep Blue
[ 232.376504] Bluetooth: Core ver 2.22
[ 232.376767] Bluetooth: HCI device and connection manager initialized
[ 232.376796] Bluetooth: HCI socket layer initialized
[ 232.376811] Bluetooth: L2CAP socket layer initialized
[ 232.376877] Bluetooth: SCO socket layer initialized
[ 245.702938] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 245.702953] Bluetooth: BNEP filters: protocol multicast
[ 245.702985] Bluetooth: BNEP socket layer initialized
root@rak-gateway:~# systemctl status bluetooth
● bluetooth.service - Bluetooth service
Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled; vendor preset: enabled)
Active: active (running) since Fri 2020-05-15 12:39:51 BST; 3min 26s ago
Docs: man:bluetoothd(8)
Main PID: 799 (bluetoothd)
Status: "Running"
Memory: 2.9M
CGroup: /system.slice/bluetooth.service
└─799 /usr/lib/bluetooth/bluetoothd
May 15 12:39:50 rak-gateway systemd[1]: Starting Bluetooth service...
May 15 12:39:51 rak-gateway bluetoothd[799]: Bluetooth daemon 5.50
May 15 12:39:51 rak-gateway systemd[1]: Started Bluetooth service.
May 15 12:39:51 rak-gateway bluetoothd[799]: Starting SDP server
May 15 12:39:51 rak-gateway bluetoothd[799]: Bluetooth management interface 1.14 initialized
root@rak-gateway:~# systemctl status hciuart
● hciuart.service - Configure Bluetooth Modems connected by UART
Loaded: loaded (/lib/systemd/system/hciuart.service; disabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Fri 2020-05-15 12:42:13 BST; 1min 6s ago
Process: 894 ExecStart=/usr/bin/btuart (code=exited, status=1/FAILURE)
May 15 12:41:43 rak-gateway systemd[1]: Starting Configure Bluetooth Modems connected by UART...
May 15 12:42:13 rak-gateway btuart[894]: Initialization timed out.
May 15 12:42:13 rak-gateway btuart[894]: bcm43xx_init
May 15 12:42:13 rak-gateway systemd[1]: hciuart.service: Control process exited, code=exited, status=1/FAILURE
May 15 12:42:13 rak-gateway systemd[1]: hciuart.service: Failed with result 'exit-code'.
May 15 12:42:13 rak-gateway systemd[1]: Failed to start Configure Bluetooth Modems connected by UART.
root@rak-gateway:~# grep bt /boot/config.txt
#dtoverlay=disable-bt
root@rak-gateway:~# hcitool dev
Devices:
root@rak-gateway:~#
Here introduces the use of Bluetooth through the bluetoothctl tool, I think you can try it.
Another idea would be to temporarily put in a different uSD card with a stock Raspbian or whatever and try all your experiments on that first without it trying to be a gateway. If you get bluetooth working there, then you know that there’s an issue of different configuration between the OS images, and you can try to identify the issue. But if it doesn’t work on a stock image, then the problem is likely a mistake in the attempt to use bluetooth…
Worst case you could also start with a stock image and follow the many instructions for turning a pi into a gateway.
That is a good idea, will try that and report back (will take some time!)
I tried the suggestion and installed Raspbian on a separate SD card and bluetooth worked out of the box. Then I executed the install script found in https://github.com/RAKWireless/rak_common_for_gateway for the RAK2246 board and this broke bluetooth again, but also the gateway itself doesn’t work:
Version: 4.0.1
Version: 5.0.1;
INFO: Little endian host
INFO: antenna_gain 0 dBi
INFO: no configuration for tx gain lut 9
INFO: no configuration for tx gain lut 10
INFO: no configuration for tx gain lut 11
INFO: no configuration for tx gain lut 12
INFO: no configuration for tx gain lut 13
INFO: no configuration for tx gain lut 14
INFO: no configuration for tx gain lut 15
INFO: Configuring TX LUT with 9 indexes
ERROR: Failed to configure concentrator TX Gain LUT
So it looks like this ends up in a lot of try-and-error. Let’s see if I ever get this to work.
At least it would be great to figure out if it even is able to work hardware-wise…
It should be able to work, unless there’s a conflict over attempts to support GPS.
Maybe try a generic gateway install procedure and not RAK’s; there’s not much unique about the hardware of the concentrator itself, except for the reset pin assignment and the unfortunate need to keep the SPI clock slow.
Hello @tobru
thank you for your feedback.
This is my fault. I set a wrong value for dig_power. I have fixed it, please push the latest code.
@tobru
Please try to comment “dtoverlay=disable-bt” in the file /boot/config.txt, Then try again if Bluetooth works.
@ZhuQI Thanks for the fix, the gateway now starts properly and connects to TTN.
But still no luck with with Bluetooth. After running the install script I compared the original config.txt and the one provided by the install script:
pi@rak-gateway:~ $ diff -u config.txt /boot/config.txt
--- config.txt 2020-07-18 13:04:18.404095485 +0100
+++ /boot/config.txt 2020-07-18 13:10:26.000000000 +0100
@@ -46,21 +46,14 @@
dtparam=i2c_arm=on
#dtparam=i2s=on
dtparam=spi=on
+dtparam=i2c1=on, dtparam=i2c_arm_baudrate=100000
-# Uncomment this to enable infrared communication.
-#dtoverlay=gpio-ir,gpio_pin=17
-#dtoverlay=gpio-ir-tx,gpio_pin=18
+# Uncomment this to enable the lirc-rpi module
+#dtoverlay=lirc-rpi
# Additional overlays and parameters are documented /boot/overlays/README
# Enable audio (loads snd_bcm2835)
dtparam=audio=on
+dtoverlay=disable-bt
-[pi4]
-# Enable DRM VC4 V3D driver on top of the dispmanx display stack
-dtoverlay=vc4-fkms-v3d
-max_framebuffers=2
-[all]
-#dtoverlay=vc4-fkms-v3d
-enable_uart=1
I then removed the line dtoverlay=disable-bt and rebooted: No luck. I then restored the original config.txt and rebooted: No luck.
The next step I’m taking is to again start from scratch with an clean Raspbian installation and try to install the gateway software manually. It looks like the installer changes something which breaks Bluetooth, but I don’t know what. Just removing / commenting the dtoverlay=disable-bt isn’t enough as it seems.
Hello @tobru
Can you try to delete “gps_tty_path” from the file /opt/ttn-gateway/packet_forwarder/lora_pkt_fwd/global_conf.json?
Please use command sudo systemctl enable hciuart.
