Buzzer 18001 overheats on WisMesh Pocket v1
  • What product do you wish to discuss? 19026 (Wismesh Pocket v1) + 18001
  • What firmware are you using? Meshtastic 2.6.4
  • How often does the problem happen? Always
  • How can we replicate the problem?
  • connect the 18001 buzzer in slot B
  • power on the board
Hello, I purchased 2 buzzers 18001 for my WisMesh Pocket v1’s. Problem is as soon as I power on the device, after connecting the buzzer on slot B, the buzzer smells and overheats.
I didn’t test if it sounds because of fear of letting it burn out. Also, I can’t use another slot because of the presence of the display.
I tried the following, to no avail:
  • changed the PWM GPIO from the default 36 to 2
  • set pin active = high
  • activated and deactivated the external notification module, it overheats regardless
  • swapped between the two modules
I also searched this forum and Meshtastic’s but it seems that no one incurred in the same problem.
Please help me understand the issue.
Best regards.
The problem with the RAK18001 in Slot B is that WB_IO2 is controlling the buzzer.
But if WB_IO2 is set to high to enable power for other modules, the buzzer gets a permanent HIGH on its control pin which leads to the overheating.
On the old WisMesh Pocket I am afraid you can’t use the buzzer.
The newer WisMesh Pocket have Sensor Slots C and D and there would be no such problem.
What other modules could be? There is none I can see, even on slots C and D, that are under the OLED.
As an experiment, could I temporarily connect the buzzer to slot A, even if there’s no fixing screw?
V2 boards have no Sensor Slots under the display, we reduced the slots to two and put them on the other side.
V1 board (called VA internally):
V2 board (called VC internally)
You can put the buzzer on the Slot A, just don’t shake your end device too much.
Great! And is it correct that i have to follow the attached table in order to get the right pin number in the Meshtastic firmware? So Slot A => WB_IO1 => GPIO 17?
Each slot has two GPIO’s.
RAK18001 in Slot A would use WB_IO1.
If you have Excel, the WisBlock IO Pin Mapper can show you which GPIO is used in which slot for the different modules.
Well, turns out I’m tired :smiley: I confused 34 with 36 because the GPIO field in the Meshtastic firmware was prefilled with 36. After changing it to 34, the buzzer works fine on slot B
