Mohamed
(Mohamed Raboudi)
July 9, 2019, 2:18pm
1
I tried to follow the steps described in this document http://docs.rakwireless.com/en/Cellular/RAK8212/Software-Development/Get_start_with_RAK8212_and_Hologram.io_using_RUI_firmware_V1.0.pdf
and I wired my J-link Edu Mini programmer to the board accordingly and used an external battery as a power source. But nrfgo Studio is not detecting the target as you can see in the attached screenshot.
I’m using the latest versions of all nrf and jlink softwares.
Could you please tell what else can I do?
Thanks.
Fomi
(Fomi Tong)
July 10, 2019, 2:09am
2
Mohamed
(Mohamed Raboudi)
July 10, 2019, 7:50am
3
Hi @Fomi ,
Thanks for your detailed response but I already tried with JFlash V6.46i (latest version) and I got the same error when connecting with your version too.
Mohamed
(Mohamed Raboudi)
July 10, 2019, 10:23am
5
Okay, I rechecked everything and it was a bad wiring issue. I can flash the firmware the original way with nrfgo studio just fine.
Thanks @Fomi
devpie
(Dev)
October 28, 2021, 8:31pm
6
Hi
All
I have the same error
failed to connect, could not establish a connection to target
I have tried shorting my cables
I have tried applying power directly to the board externally from the 3.3v output from j-link
Please help
Is it because it is too less amps
How did you resolve
Thanks all
