Can't access SDCard via SPI on Wisblock RAK4631
I’m using a custom code I developed to save all console logs to an SD card based on the Zephyr architecture. I originally developed it for the Thingy:52 and have also used it successfully on the nRF52 DK and nRF52840 DK boards.
Recently, I tried running it on the WisBlock RAK4631, but it didn’t work. I tried several fixes, but none of them solved the issue. At first, I attempted to use the available pins on the WisBlock, but none of them worked. Then, I tried soldering the four SD pins to the QSPI pins on the pinout (P0.03, P0.30, P0.29, P0.26), since I found somewhere that these pins could also be configured for SPI.
Here’s the code I tried:
“sd_card.c”
#include "sd_card.h"
LOG_MODULE_REGISTER(SD_CARD, LOG_LEVEL_INF);
FATFS fatfs;
static struct fs_mount_t fatfs_mnt = {
    .type = FS_FATFS,
    .mnt_point = MOUNT_POINT,
    .fs_data = &fatfs,
void init_sd_card() {
    static const char *disk_pdrv = "SD";
    uint64_t memory_size_mb;
    uint32_t block_count;
    uint32_t block_size;
    uint32_t err = disk_access_init(disk_pdrv);
    if (err != 0) {
        LOG_ERR("Storage init Error! %d", err);
        k_sleep(K_MSEC(REBOOT_INTERVAL));
        sys_reboot(SYS_REBOOT_COLD);
    if (disk_access_ioctl(disk_pdrv, DISK_IOCTL_GET_SECTOR_COUNT, &block_count)) {
        LOG_ERR("Unable to get sector count");
    if (disk_access_ioctl(disk_pdrv, DISK_IOCTL_GET_SECTOR_SIZE, &block_size)) {
        LOG_ERR("Unable to get sector size");
    memory_size_mb = (uint64_t)block_count * block_size;
    LOG_INF("Memory Size %uMB", (uint32_t)(memory_size_mb >> 20));
    int res = fs_mount(&fatfs_mnt);
    if (res == FR_OK) {
        LOG_INF("Disk mounted");
    } else {
        LOG_ERR("Error mounting disk (E: %i)", res);
“sd_card.h”
#ifndef SD_CARD_H
#define SD_CARD_H
#include <zephyr/storage/disk_access.h>
#include <zephyr/logging/log.h>
#include <zephyr/logging/log_backend.h>
#include <zephyr/fs/fs.h>
#include <zephyr/sys/reboot.h>
#include <ff.h>
#define MOUNT_POINT "/SD:"          ///< Mount point for the SD card
#define REBOOT_INTERVAL (2 * 1000)  ///< Delay before reboot (ms)
extern FATFS fatfs;             ///< File system object for the SD card
 * @brief Initializes the SD Card functionality.
 * This function verifies if the SD Card device is ready for operation.
 * If the device is not ready or some error occours in mouting, an error
 * is logged, and the system reboots after a short delay defined by REBOOT_INTERVAL.
 * If the device is ready, a confirmation message is logged.
 * @return void This function does not return a value.
void init_sd_card();
#endif // SD_CARD_H
“main.c”
LOG_MODULE_REGISTER(MAIN, LOG_LEVEL_INF);
int main() {
    LOG_INF("Running on board: %s", CONFIG_BOARD);
    k_sleep(K_SECONDS(2));
    init_sd_card();
    LOG_INF("Test Application Started");
    return 0;
“proj.conf”
CONFIG_I2C=n
CONFIG_LOG=y
CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=2048
CONFIG_MAIN_STACK_SIZE=2048
CONFIG_REBOOT=y
CONFIG_MULTITHREADING=y
CONFIG_VOLTAGE_DIVIDER=y
CONFIG_ADC=y
CONFIG_DISK_ACCESS=y
CONFIG_FILE_SYSTEM=y
CONFIG_FAT_FILESYSTEM_ELM=y
CONFIG_LOG_BACKEND_FS=y
CONFIG_LOG_BACKEND_FS_OUTPUT_TEXT=y
CONFIG_LOG_BACKEND_FS_DIR="/SD:"
CONFIG_LOG_BACKEND_FS_FILE_PREFIX="log"
CONFIG_LOG_BACKEND_FS_FILES_LIMIT=512
CONFIG_LOG_BACKEND_FS_FILE_SIZE=8388608
CONFIG_LOG_BACKEND_FS_OVERWRITE=y
If you could help me figure out what might be wrong or suggest how to make it work on the RAK4631, I’d be very grateful.
Hello @Yopoitio
Welcome to forum. Can you please try to use attached overlay file? Let’s see this will fix your project.
Probably, some pins are used by other peripherals.
rak4631.overlay.zip (851 Bytes)
Best regards,
Sercan.
I will do it, but I don’t have the board with me right now. I’ll take care of it on Monday and report back.
Thank you in advance.
Sorry for the late response. I wasn’t able to test it last week because the board was being used for other tests. In the meantime, I tested the solution and unfortunately it still doesn’t work…
Here is the error:
00> *** Booting nRF Connect SDK v3.0.2-89ba1294ac9b ***
00> *** Using Zephyr OS v4.0.99-f791c49f492c ***
00> [00:00:00.250,061] <inf> MAIN: Running on board: rak4631
00> [00:00:02.457,763] <err> sd: Card error on CMD0
00> [00:00:02.457,794] <inf> sd: Card does not support CMD8, assuming legacy card
00> [00:00:02.661,773] <err> SD_CARD: Storage init Error! -116
