Issue: Cellular network configuration
Setup:
LoRa® Server:
Details: I recently started using the RAK7240 WisGate Edge Prime. in that I was set my gateway on the cellular network. So, when I was using the jio sim the network setup the network shows jio 4G FDD LTE and I am able to use cellular services but when I tried to switch on another network like Vodafone, Idea, airtel all the time network status was undefined. So, what was issues with other network and I already tried with many APN setting.
velev
(Todor Velev)
January 27, 2021, 10:33am
2
Hi @vivek.machchhar can you share your system log? It is located on the SD card.
[quote=“velev, post:2, topic:3563, full:true”]
Yes,
Wed Jan 27 16:06:23 2021 daemon.notice netifd: wwan (3115): Sending discover…
Wed Jan 27 16:06:24 2021 daemon.err uhttpd[1512]: connect ERROR: Connection refused
Wed Jan 27 16:06:25 2021 daemon.err uhttpd[1512]: connect ERROR: Connection refused
Wed Jan 27 16:06:26 2021 daemon.notice netifd: wwan (3115): Sending discover…
Wed Jan 27 16:06:30 2021 daemon.err uhttpd[1512]: connect ERROR: Connection refused
Wed Jan 27 16:06:31 2021 kern.info quectel-CM[2513]: Find /sys/bus/usb/devices/1-1.1 idVendor=2c7c idProduct=0195
Wed Jan 27 16:06:31 2021 kern.info quectel-CM[2513]: Find /sys/bus/usb/devices/1-1.1:1.4/net/wwan0
Wed Jan 27 16:06:31 2021 kern.info quectel-CM[2513]: Find usbnet_adapter = wwan0
Wed Jan 27 16:06:31 2021 kern.info quectel-CM[2513]: Find /sys/bus/usb/devices/1-1.1:1.4/usbmisc/cdc-wdm0
Wed Jan 27 16:06:31 2021 kern.info quectel-CM[2513]: Find qmichannel = /dev/cdc-wdm0
Wed Jan 27 16:06:31 2021 kern.info quectel-CM[2513]: cdc_wdm_fd = 7
Wed Jan 27 16:06:32 2021 kern.info quectel-CM[2513]: Get clientWDS = 20
Wed Jan 27 16:06:32 2021 kern.info quectel-CM[2513]: Get clientDMS = 1
Wed Jan 27 16:06:32 2021 kern.info quectel-CM[2513]: Get clientNAS = 4
Wed Jan 27 16:06:32 2021 kern.info quectel-CM[2513]: Get clientUIM = 1
Wed Jan 27 16:06:32 2021 kern.info quectel-CM[2513]: Get clientWDA = 1
Wed Jan 27 16:06:32 2021 kern.info quectel-CM[2513]: requestBaseBandVersion EG95NAFBR05A04M4G
Wed Jan 27 16:06:32 2021 kern.info quectel-CM[2513]: requestGetSIMStatus SIMStatus: SIM_READY
Wed Jan 27 16:06:32 2021 kern.info quectel-CM[2513]: requestGetICCID DeviceICCID: 8991000903756109721P
Wed Jan 27 16:06:32 2021 kern.info quectel-CM[2513]: requestGetIMSI DeviceIMSI: 404980297656964
Wed Jan 27 16:06:32 2021 kern.info quectel-CM[2513]: requestSetProfile[1] airtelgprs.com///0
Wed Jan 27 16:06:32 2021 kern.info quectel-CM[2513]: requestGetProfile[1] airtelgprs.com///0
Wed Jan 27 16:06:32 2021 kern.info quectel-CM[2513]: requestRegistrationState2 MCC: 0, MNC: 0, PS: Detached, DataCap: UNKNOW
Wed Jan 27 16:06:32 2021 kern.info quectel-CM[2513]: requestQueryDataCall IPv4ConnectionStatus: DISCONNECTED
Wed Jan 27 16:06:32 2021 kern.info quectel-CM[2513]: Dail Failed 1
Wed Jan 27 16:06:37 2021 kern.info quectel-CM[2513]: requestRegistrationState2 MCC: 0, MNC: 0, PS: Detached, DataCap: UNKNOW
Wed Jan 27 16:06:37 2021 kern.info quectel-CM[2513]: Dail Failed 2
Wed Jan 27 16:06:42 2021 kern.info quectel-CM[2513]: requestRegistrationState2 MCC: 0, MNC: 0, PS: Detached, DataCap: UNKNOW
Wed Jan 27 16:06:42 2021 kern.info quectel-CM[2513]: Dail Failed 3
Wed Jan 27 16:06:47 2021 kern.info quectel-CM[2513]: requestRegistrationState2 MCC: 0, MNC: 0, PS: Detached, DataCap: UNKNOW
Wed Jan 27 16:06:47 2021 kern.info quectel-CM[2513]: Dail Failed 4
Wed Jan 27 16:06:49 2021 kern.info quectel-CM[2513]: requestRegistrationState2 MCC: 405, MNC: 857, PS: Detached, DataCap: UNKNOW
Wed Jan 27 16:06:52 2021 user.notice lora_pkt_fwd[1641]:
2021-01-27 10:36:52 UTC
Wed Jan 27 16:06:52 2021 user.notice lora_pkt_fwd[1641]: ### [UPSTREAM] ###
Wed Jan 27 16:06:52 2021 user.notice lora_pkt_fwd[1641]: # RF packets received by concentrator: 0
Wed Jan 27 16:06:52 2021 user.notice lora_pkt_fwd[1641]: # CRC_OK: 0.00, CRC_FAIL: 0.00, NO_CRC: 0.00
Wed Jan 27 16:06:52 2021 user.notice lora_pkt_fwd[1641]: # RF packets forwarded: 0 (0 bytes)
Wed Jan 27 16:06:52 2021 user.notice lora_pkt_fwd[1641]: # PUSH_DATA datagrams sent: 1 (133 bytes)
Wed Jan 27 16:06:52 2021 user.notice lora_pkt_fwd[1641]: # PUSH_DATA acknowledged: 100.00
Wed Jan 27 16:06:52 2021 user.notice lora_pkt_fwd[1641]: ### [DOWNSTREAM] ###
Wed Jan 27 16:06:52 2021 user.notice lora_pkt_fwd[1641]: # PULL_DATA sent: 6 (100.00 acknowledged)
Wed Jan 27 16:06:52 2021 user.notice lora_pkt_fwd[1641]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Wed Jan 27 16:06:52 2021 user.notice lora_pkt_fwd[1641]: # RF packets sent to concentrator: 0 (0 bytes)
Wed Jan 27 16:06:52 2021 user.notice lora_pkt_fwd[1641]: # TX errors: 0
Wed Jan 27 16:06:52 2021 user.notice lora_pkt_fwd[1641]: # BEACON queued: 0
Wed Jan 27 16:06:52 2021 user.notice lora_pkt_fwd[1641]: # BEACON sent so far: 0
Wed Jan 27 16:06:52 2021 user.notice lora_pkt_fwd[1641]: # BEACON rejected: 0
Wed Jan 27 16:06:52 2021 user.notice lora_pkt_fwd[1641]: ### [JIT] ###
Wed Jan 27 16:06:52 2021 user.notice lora_pkt_fwd[1641]: # SX1301/SX1302 time (PPS): 73994654, offset us 0
Wed Jan 27 16:06:52 2021 user.notice lora_pkt_fwd[1641]: ### [GPS] ###
Wed Jan 27 16:06:52 2021 user.notice lora_pkt_fwd[1641]: # Invalid time reference (age: 1611743812 sec)
Wed Jan 27 16:06:52 2021 user.notice lora_pkt_fwd[1641]: # no valid GPS coordinates available yet
Wed Jan 27 16:06:52 2021 user.notice lora_pkt_fwd[1641]: ##### END #####
