Hello everyone!
I just bought a RAK7249 LoraGateway. I want to connect to Asia server (router.as1.thethings.network). But when I open LUCI web to edit parameters, it seems to default connect to EU863-870. I flashed a new firmware from the link (https://downloads.rakwireless.com/en/LoRa/DIY-Gateway-RAK7249/Firmware/). And no difference in my device.
. So, I need a firmware included parameters connect to Asia server. Or Do you have a document relative to my issue? Thank you for the information
NhanLee
This is the tab for the built in Lora server.
You want to go to Lora Gateway - >Packet forwarder. There is a drop down menu, with the option to use the Semtech packet forwarder. Once chosen you should see a field below it with the router address. Adhust it to the Asian one.
