Change the settings of the uplink interval over the air
Issue: How to change transmission time over the air
Setup: RAK5205
Server: Chirpstack
Details: Hi I’m looking for information on how I can change the settings of the uplink interval over the air. Is it possible to send AT commands to the 5202? For example, I would like to use the following AT command over the air “at+set_config=lora:send_interval:X:Y”
Is there any documentation explaining what can be sent?
Hi @88bit ,
Sadly that is not possible on RAK5202 default AT commands. You have to write your own custom firmware to have the feature. You can consider to try to use WisBlock.
