This is my setup with RAK7371 WisGate Developer Base connected with USB to a RaspberryPi4B
chirpstack-gateway-bridge
cat docker-compose.yml
version: '3.6'
networks:
loranet:
external: true
services:
chirpstack-gateway-bridge:
image: chirpstack/chirpstack-gateway-bridge:3.14.0
container_name: gatewaybridge
hostname: gatewaybridge
restart: always
logging:
options:
max-size: "10m"
max-file: "3"
ports:
- "1700:1700/udp"
volumes:
- ./chirpstack-gateway-bridge.toml:/etc/chirpstack-gateway-bridge/chirpstack-gateway-bridge.toml
networks:
loranet:
udp-packet-forwarder
version: '3.6'
networks:
loranet:
external: true
services:
udp-packet-forwarder:
image: rakwireless/udp-packet-forwarder:v1.1.3
container_name: udpforwarder
hostname: udpforwarder
restart: always
logging:
options:
max-size: "10m"
max-file: "3"
privileged: true
volumes:
- ./global_conf.json:/app/global_conf.json:ro
environment:
MODEL: "RAK7371"
MODULE: "RAK5146"
CONCENTRATOR: "SX1303"
HAS_GPS: "0"
INTERFACE: "USB"
GATEWAY_EUI: "26E804FFFE7093C0"
SERVER_HOST: "gatewaybridge.loranet"
SERVER_PORT: "1700"
RADIO_DEV: "/dev/ttyACM0"
GATEWAY_EUI_NIC: "usb0"
BAND: "us_902_928"
networks:
loranet:
RabbitMQ mqtt plugin is enabled, where I see the connection established from chirpstack-gateway-bridge container. A queue is created mqtt-subscription-66C0A7FC63D30000qos0 which confirms successful creation of all the containers and the connection between chirpstack-gateway-bridge and rabbitmq is working.
But when I send data from lora devices I do not see any data received by chirpstack-gateway-bridge or rabbitmq.
Is there any documentation to how to setup wis developer gateway with chirpstack-gateway-bridge and store data to RabbitMQ?
