Hey Chris, the device is in Class C Mode, I’m using the AS923 region so AT+RX2DR returned 2, here’s the code that im running on my rak11720 device (check the previous post for more details):
void recvCallback(SERVICE_LORA_RECEIVE_T * data) {
if (data->BufferSize > 0) {
Serial.print("\r\n");
void setup()
delay(2000);
Serial.println("RAKwireless LoRaWan Multicast Example");
int ret;
if(api.lorawan.nwm.get() != 1)
Serial.printf("Set Node device work mode %s\r\n",
api.lorawan.nwm.set() ? "Success" : "Fail");
api.system.reboot();
// OTAA Device EUI MSB
uint8_t node_device_eui[8] =
{ 0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07, 0x88 };
// OTAA Application EUI MSB
uint8_t node_app_eui[8] =
{ 0x0E, 0x0D, 0x0D, 0x01, 0x0E, 0x01, 0x02, 0x0F };
// OTAA Application Key MSB
uint8_t node_app_key[16] =
{ 0x2B, 0x7E, 0x15, 0x16, 0x28, 0xAE, 0xD2, 0xA6, 0xAB, 0xF7, 0x15,
0x88, 0x09, 0xCF, 0x4F, 0x3E };
/**LoRaWan Multicast Session*/
uint8_t node_mc_address[4] = { 0x01, 0x02, 0x03, 0x04 };
uint8_t node_mc_AppSKey[16] =
{ 0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07, 0x08, 0x01, 0x02, 0x03,
0x04, 0x05, 0x06, 0x07, 0x08 };
uint8_t node_mc_NwkSKey[16] =
// RAK_LORA_McSession session = {
// .McDevclass = 2,
// .McAddress =
// node_mc_address[0] << 24 | node_mc_address[1] << 16 |
// node_mc_address[2] << 8 | node_mc_address[3],
// .McFrequency = 923000000,
// .McDatarate = 2,
// .McPeriodicity = 0,
// .McGroupID = 2,
// .entry = 0,
// memcpy(session.McAppSKey, node_mc_AppSKey, 16);
// memcpy(session.McNwkSKey, node_mc_NwkSKey, 16);
if (!(ret = api.lorawan.appeui.set(node_app_eui, 8))) {
Serial.printf("LoRaWan Multicast - set device EUI is incorrect! \r\n");
return;
if (!(ret = api.lorawan.appkey.set(node_app_key, 16))) {
Serial.printf("LoRaWan Multicast - set application EUI is incorrect! \r\n");
return;
if (!(ret = api.lorawan.deui.set(node_device_eui, 8))) {
Serial.printf("LoRaWan Multicast - set application key is incorrect! \r\n");
return;
* LoRaWAN band setting:
* EU433: 0
* CN470: 1
* RU864: 2
* IN865: 3
* EU868: 4
* US915: 5
* AU915: 6
* KR920: 7
* AS923: 8
if (!(ret = api.lorawan.band.set(8))) {
Serial.printf("LoRaWan Multicast - set band is incorrect! \r\n");
return;
if (!(ret = api.lorawan.njm.set(RAK_LORA_OTAA))) {
Serial.printf("LoRaWan Multicast - set network join mode is incorrect! \r\n");
return;
if (!(ret = api.lorawan.deviceClass.set(RAK_LORA_CLASS_C))) {
Serial.printf("LoRaWan Multicast - set device class is incorrect! \r\n");
return;
if (!(ret = api.lorawan.join())) {
Serial.printf("LoRaWan Multicast - join fail! \r\n");
return;
/**Wait for Join success */
Serial.print("Waiting for Lorawan join...");
api.lorawan.join();
delay(10000);
// // Get device address
// api.lorawan.daddr.get(node_mc_address, 4);
// // Add address to MC sessionZ
// session.McAddress = node_mc_address[0] << 24 | node_mc_address[1] << 16 | node_mc_address[2] << 8 | node_mc_address[3];
api.lorawan.adr.set(true);
api.lorawan.rety.set(1);
api.lorawan.cfm.set(1);
/**LoRaWAN Multicast Setting*/
// if (api.lorawan.addmulc(session) == true) {
// Serial.println("Add Multicast Success");
// } else {
// Serial.println("Add Multicast Fail");
void loop()
