I would like help writing the script for the Rakwireless RAK4631: (Core), RAK1906: (Environment Sensor) and RAK1903: (Light Sensor); which provides sensor readers for Ambient light, Air pressure, Temperature, Humidity, Indoor Air Quality Index, and CO2 equivalent. The data will then be transmitted to my Rak LoRaWan gateway on the TTN every 10 secs.
I’m still very new to Arduino programming and don’t fully understand the C++ syntax yet.
I have tried to merge the two example scripts sketches found within the Arduino IDE, however, i’m getting an error message of:
/private/var/folders/br/rm5jwy_n4pd4n7sg7kmljfjr0000gn/T/.arduinoIDE-unsaved202322-41426-1582inw.mznfe/basic/basic.ino: In function 'void loop()':
/private/var/folders/br/rm5jwy_n4pd4n7sg7kmljfjr0000gn/T/.arduinoIDE-unsaved202322-41426-1582inw.mznfe/basic/basic.ino:168:55: error: invalid use of void expression
exit status 1
Compilation error: invalid use of void expression
My script is as follows:
Please note: I haven’t included the logic for the LoRaWAN transfer because I wanted to achieve this step first, however, if someone can support with that I would be most thankful.
#include <bsec.h>
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_BME680.h> // Click to install library: http://librarymanager/All#Adafruit_BME680
#include <ClosedCube_OPT3001.h> // Click here to get the library: http://librarymanager/All#OPT3001
// Helper functions declarations
void checkIaqSensorStatus(void);
void errLeds(void);
// Create an object of the class Bsec
Bsec iaqSensor;
String output;
Adafruit_BME680 bme;
// Might need adjustments
#define SEALEVELPRESSURE_HPA (1010.0)
// Forward declarations for functions
void printError(String text, OPT3001_ErrorCode error);
ClosedCube_OPT3001 g_opt3001;
#define OPT3001_ADDRESS 0x44
void configureSensor()
OPT3001_Config newConfig;
newConfig.RangeNumber = B1100;
newConfig.ConvertionTime = B0;
newConfig.Latch = B1;
newConfig.ModeOfConversionOperation = B11;
OPT3001_ErrorCode errorConfig = g_opt3001.writeConfig(newConfig);
if (errorConfig != NO_ERROR)
printError("OPT3001 configuration", errorConfig);
else
OPT3001_Config sensorConfig = g_opt3001.readConfig();
Serial.println("OPT3001 Current Config:");
Serial.println("------------------------------");
Serial.print("Conversion ready (R):");
Serial.println(sensorConfig.ConversionReady, HEX);
Serial.print("Conversion time (R/W):");
Serial.println(sensorConfig.ConvertionTime, HEX);
Serial.print("Fault count field (R/W):");
Serial.println(sensorConfig.FaultCount, HEX);
Serial.print("Flag high field (R-only):");
Serial.println(sensorConfig.FlagHigh, HEX);
Serial.print("Flag low field (R-only):");
Serial.println(sensorConfig.FlagLow, HEX);
Serial.print("Latch field (R/W):");
Serial.println(sensorConfig.Latch, HEX);
Serial.print("Mask exponent field (R/W):");
Serial.println(sensorConfig.MaskExponent, HEX);
Serial.print("Mode of conversion operation (R/W):");
Serial.println(sensorConfig.ModeOfConversionOperation, HEX);
Serial.print("Polarity field (R/W):");
Serial.println(sensorConfig.Polarity, HEX);
Serial.print("Overflow flag (R-only):");
Serial.println(sensorConfig.OverflowFlag, HEX);
Serial.print("Range number (R/W):");
Serial.println(sensorConfig.RangeNumber, HEX);
void opt3001_lux_level()
OPT3001 result = g_opt3001.readResult();
uint16_t luxLuminosity = result.lux;
void opt3001_read_data()
uint16_t luminosity = result.lux;
if (result.error == NO_ERROR)
else
printError("OPT3001", result.error);
Serial.print(text);
Serial.print(": [ERROR] Code #");
Serial.println(error);
// Entry point for the example
void setup(void)
while (!Serial) delay(10); // wait for console
Wire.begin();
iaqSensor.begin(BME680_I2C_ADDR_SECONDARY, Wire);
output = "\nBSEC library version " + String(iaqSensor.version.major) + "." + String(iaqSensor.version.minor) + "." + String(iaqSensor.version.major_bugfix) + "." + String(iaqSensor.version.minor_bugfix);
Serial.println(output);
checkIaqSensorStatus();
bsec_virtual_sensor_t sensorList[10] = {
BSEC_OUTPUT_RAW_TEMPERATURE,
BSEC_OUTPUT_RAW_PRESSURE,
BSEC_OUTPUT_RAW_HUMIDITY,
BSEC_OUTPUT_RAW_GAS,
BSEC_OUTPUT_IAQ,
BSEC_OUTPUT_STATIC_IAQ,
BSEC_OUTPUT_CO2_EQUIVALENT,
BSEC_OUTPUT_BREATH_VOC_EQUIVALENT,
BSEC_OUTPUT_SENSOR_HEAT_COMPENSATED_TEMPERATURE,
BSEC_OUTPUT_SENSOR_HEAT_COMPENSATED_HUMIDITY,
/* opt3001 init */
g_opt3001.begin(OPT3001_ADDRESS);
Serial.print("OPT3001 Manufacturer ID");
Serial.println(g_opt3001.readManufacturerID());
Serial.print("OPT3001 Device ID");
Serial.println(g_opt3001.readDeviceID());
configureSensor();
iaqSensor.updateSubscription(sensorList, 10, BSEC_SAMPLE_RATE_LP);
// Function that is looped forever
void loop(void)
unsigned long time_trigger = millis();
if (iaqSensor.run()) { // If new data is available
output = String(time_trigger);
output += ", R.Temp: " + String(iaqSensor.rawTemperature) + "°C" ;
output += ", R.Prs: " + String(iaqSensor.pressure) + "hPa";
output += ", R.Hum: " + String(iaqSensor.rawHumidity) + "%";
output += ", Gas: " + String(iaqSensor.gasResistance) + "Ohms";
output += ", IAQ: " + String(iaqSensor.iaq) + "idx";
output += ", IAQ (acc): " + String(iaqSensor.iaqAccuracy) + "+-";
output += ", Temp: " + String(iaqSensor.temperature) + "°C";
output += ", Prs: " + String(iaqSensor.humidity) + "%";
output += ", Static IAQ: " + String(iaqSensor.staticIaq) + "idx";
output += ", CO2: " + String(iaqSensor.co2Equivalent) + "lvl";
output += ", VOC: " + String(iaqSensor.breathVocEquivalent) + "lvl";
output += ", Light: " + String(opt3001_read_data()) + "lux";
} else {
// Helper function definitions
if (iaqSensor.status != BSEC_OK) {
if (iaqSensor.status < BSEC_OK) {
output = "BSEC error code : " + String(iaqSensor.status);
for (;;)
errLeds(); /* Halt in case of failure */
} else {
output = "BSEC warning code : " + String(iaqSensor.status);
if (iaqSensor.bme680Status != BME680_OK) {
if (iaqSensor.bme680Status < BME680_OK) {
output = "BME680 error code : " + String(iaqSensor.bme680Status);
for (;;)
} else {
output = "BME680 warning code : " + String(iaqSensor.bme680Status);
void errLeds(void)
pinMode(LED_BUILTIN, OUTPUT);
delay(100);
delay(100);
