Communication, lora antenna range through arduino ide of rak4360
I have Lora Rakwireless Wisblock Rak4630 and esp32+arduino mega 2560 without lora, I want to communication between them. And I want to know lora antenna range through arduino ide and want to on/off RFID/GPS feature in code? is anyone can help me > I tried everything on online still nothing is working. Help me.
Welcome to RAK forum @thakurcodes .
It is a little bit confusing what issue you have but these are my thoughts based on your question/s.
  1. Is the RAK4630 communicating to ESP32 and/or Arduino Mega via AT command? Is that what you mean with “communication between them”? Or there is another LoRa module you want to communicate with?
  2. “know lora antenna range through arduino ide” LoRa range cannot be found in the IDE or any command. LoRa range is a factor of many variables like antenna used, TX power, environment, spreading factor setting, etc.
I am new to IOT platform, So i have only two module, one is esp32 and other is Mestastic Wisblock Rak4630 with LoRa antenna and BLE antenna. I want o knew these few things as follows :-
1 :- Communication between them through BLE. Can we communicate with Lora Antenna too?
2:- If I have a code where I can read RFID/NFC tags and locate a location, How do I on and off them according to requirements?
3: Distance between Lora and receiver device.
I already installed necessary library (nrf and rui nrf) and board.
I will have soon a module, SX1262-LoRa-DTU-HF that is on receiver end. And Wisblock RAK4630 on sender end. I don’t have any leads regarding this, but hoping so I will make some setup out of it.
