Hi
I’m following this guide, but when I try to compile my code, I’m seeing this error:
src/main.h:10:39: error: 'APP_TIMER_SCHED_EVENT_DATA_SIZE' was not declared in this scope
I found, that it is defined in app_timer.h, but I cannot include it, when included, during ‘build’ with PlatformIO this file cannot be found:
In file included from src/main.cpp:30:0:
src/main.h:5:10: fatal error: app_scheduler.h: No such file or directory
The rest of the code compiles fine, if I enter any integer there, it compiles nicely.
This is the top part of my main.h:
#include <Arduino.h>
#include <SPI.h>
#include "secrets.h"
#include <Adafruit_BME680.h> // Click to install library: http://librarymanager/All#Adafruit_BME680
const int OTAA = 1; // OTAA is used by default.
const int SCHED_MAX_EVENT_DATA_SIZE = APP_TIMER_SCHED_EVENT_DATA_SIZE; /**< Maximum size of scheduler events. */
const int SCHED_QUEUE_SIZE = 60; /**< Maximum number of events in the scheduler queue. */
const int LORAWAN_DATERATE = DR_0; /*LoRaMac datarates definition, from DR_0 to DR_5*/
const int LORAWAN_TX_POWER = TX_POWER_5; /*LoRaMac tx power definition, from TX_POWER_0 to TX_POWER_15*/
const int JOINREQ_NBTRIALS = 3; /**< Number of trials for the join request. */
const DeviceClass_t CURRENT_CLASS = CLASS_A;
const eLoRaMacRegion_t CURRENT_REGION = LORAMAC_REGION_EU868; /* Region:EU868*/
const lmh_confirm CURRENT_CONFIRM = LMH_UNCONFIRMED_MSG; /* confirm/unconfirm packet definition*/
const int PORT = LORAWAN_APP_PORT; /* data port*/
Why does this define not exist here, and what should I do?
