Hello everyone,
I have a problem connecting BasicStation to Chirpstack Network Server. I am using this portainer templates from RAKWireless and run it on RAK7391.
I try to connect the BasicStation to TTN and it is work successfully, but when I tried to connect it to the Chirpstack Network Server it is always failed. From the template the open port for the Chirpstack Gateway Bridge is on 1700 udp, I think it is for the UDP Packet Forwarder, so I edit the chirpstack.yml and open port 3001 for websocket, I change it like this:
chirpstack-gateway-bridge:
image: chirpstack/chirpstack-gateway-bridge:3
restart: unless-stopped
ports:
- 3001:3001
environment:
- TZ=${TZ:-Europe/London}
- PUID=${PUID:-1000}
- PGID=${PGID:-100}
- INTEGRATION__MQTT__AUTH__GENERIC__SERVERS=tcp://mosquitto:1883
- BACKEND__TYPE=basic_station
- BACKEND__BASIC_STATION__BIND=:3001
- BACKEND__BASIC_STATION__REGION=US915
- BACKEND__BASIC_STATION__FREQUENCY_MIN=902000000
- BACKEND__BASIC_STATION__FREQUENCY_MAX=928000000
- BACKEND__BASIC_STATION__CONCENTRATORS__LORA_STD__FREQUENCY=923300000
- BACKEND__BASIC_STATION__CONCENTRATORS__LORA_STD__BANDWIDTH=500000
- BACKEND__BASIC_STATION__CONCENTRATORS__LORA_STD__SPREADING_FACTOR=7
depends_on:
- mosquitto
what I add is this line:
The logs for BasicStation is like this:
2023-06-21 12:38:02.941 [TCE:INFO] Connecting to INFOS: ws://192.168.241.51:3001
2023-06-21 12:38:02.943 [TCE:INFO] Infos: e45f:01ff:febc:9afe e45f:01ff:febc:9afe ws://192.168.241.51:3001/gateway/e45f01fffebc9afe
2023-06-21 12:38:02.944 [AIO:DEBU] [4] ws_close reason=1000
2023-06-21 12:38:02.944 [AIO:DEBU] Echoing close - reason=1000
2023-06-21 12:38:02.944 [AIO:ERRO] Recv failed: NET - Connection was reset by peer
2023-06-21 12:38:02.944 [AIO:DEBU] [4] WS connection shutdown...
2023-06-21 12:38:02.944 [TCE:VERB] Connecting to MUXS...
2023-06-21 12:38:02.946 [TCE:VERB] Connected to MUXS.
2023-06-21 12:38:02.947 [RAL:ERRO] sx1301_conf is empty but a hw setup IS required - no fallbacks
2023-06-21 12:38:02.947 [any:ERRO] Closing connection to muxs - error in s2e_onMsg
2023-06-21 12:38:02.947 [AIO:DEBU] [4] ws_close reason=1000
2023-06-21 12:38:02.947 [AIO:DEBU] Echoing close - reason=1000
2023-06-21 12:38:02.948 [AIO:DEBU] [4|WS] Server sent close: reason=1000
2023-06-21 12:38:02.948 [AIO:DEBU] [4] WS connection shutdown...
2023-06-21 12:38:02.948 [TCE:VERB] Connection to MUXS closed in state -1
2023-06-21 12:38:02.948 [TCE:INFO] INFOS reconnect backoff 10s (retry 1)
And the logs for the Chirpstack Gateway Bridge is like this:
time="2023-06-21T12:37:42.930155675Z" level=info msg="backend/basicstation: router-config message sent to gateway" gateway_id=e45f01fffebc9afe
time="2023-06-21T12:37:42.93092333Z" level=info msg="backend/basicstation: gateway disconnected" gateway_id=e45f01fffebc9afe remote_addr="192.168.241.51:45956"
time="2023-06-21T12:37:52.935183856Z" level=info msg="backend/basicstation: router-info request received" gateway_id=e45f01fffebc9afe remote_addr="192.168.241.51:39122" router_uri="ws://192.168.241.51:3001/gateway/e45f01fffebc9afe"
time="2023-06-21T12:37:52.93873854Z" level=info msg="backend/basicstation: gateway connected" gateway_id=e45f01fffebc9afe remote_addr="192.168.241.51:39132"
time="2023-06-21T12:37:52.939419881Z" level=info msg="backend/basicstation: gateway version received" firmware= gateway_id=e45f01fffebc9afe model=corecell package= protocol=2 station="2.0.6(corecell/stdn)"
time="2023-06-21T12:37:52.940125425Z" level=info msg="backend/basicstation: router-config message sent to gateway" gateway_id=e45f01fffebc9afe
time="2023-06-21T12:37:52.940920672Z" level=info msg="backend/basicstation: gateway disconnected" gateway_id=e45f01fffebc9afe remote_addr="192.168.241.51:39132"
time="2023-06-21T12:38:02.943970152Z" level=info msg="backend/basicstation: router-info request received" gateway_id=e45f01fffebc9afe remote_addr="192.168.241.51:51050" router_uri="ws://192.168.241.51:3001/gateway/e45f01fffebc9afe"
time="2023-06-21T12:38:02.946452964Z" level=info msg="backend/basicstation: gateway connected" gateway_id=e45f01fffebc9afe remote_addr="192.168.241.51:51058"
time="2023-06-21T12:38:02.947052233Z" level=info msg="backend/basicstation: gateway version received" firmware= gateway_id=e45f01fffebc9afe model=corecell package= protocol=2 station="2.0.6(corecell/stdn)"
time="2023-06-21T12:38:02.947428541Z" level=info msg="backend/basicstation: router-config message sent to gateway" gateway_id=e45f01fffebc9afe
time="2023-06-21T12:38:02.948173141Z" level=info msg="backend/basicstation: gateway disconnected" gateway_id=e45f01fffebc9afe remote_addr="192.168.241.51:51058"
Where I do wrong? And is there any documentation to connecting the BasicStation to the Chirpstack Network Server with this portainer templates?
