Connect failure RAK4630 AU915 to Everynet
Issue:
I cant make it work with OTAA example code in RAK4630, and for some reason the device changes it port after it programmed (it starts with port 4 and after uploading, it is port 6) It happen always but after a couple restart/disconnect, it works again.
Setup: AU915 sub band 2 (Chile)
Running: RAK7200->Everynet Gw->Everynet
Failing: RAK4630->Everynet Gw->Everynet
Docs:
Using official code: WisBlock/examples/RAK4630/communications/LoRa/LoRaWAN/LoRaWAN_OTAA_ABP/LoRaWAN_OTAA_ABP.ino at master · RAKWireless/WisBlock · GitHub
Testing 2nd official code (is not the same as before): WisBlock/examples/RAK4630/communications/LoRa/LoRaWAN at master · RAKWireless/WisBlock · GitHub
Testing some recommendation from: GitHub - beegee-tokyo/SX126x-Arduino: Arduino library to use Semtech SX126x LoRa chips and modules to communicate
Details:
I have tested:
  • Change many parameters code in “lmh_param_t”: nothing
  • Creating many new EUIS and keys (i know are MSB): nothings
  • Adding Radio.IrqProcess() in loop (i dont know why it exist in some example codes and others don’t)
  • Changing ChannelsMask in RegionAU915.cpp inside SX126x-Arduino library.
  • Uncomment line 45 to 47 inside Commissioning.h inside SX126x-Arduino library.
Code:
#include <Arduino.h>
#include <LoRaWan-RAK4630.h>
#include <SPI.h>
// RAK4630 supply two LED
#ifndef LED_BUILTIN
#define LED_BUILTIN 35
#endif
#ifndef LED_BUILTIN2
#define LED_BUILTIN2 36
#endif
bool doOTAA = true;
#define SCHED_MAX_EVENT_DATA_SIZE APP_TIMER_SCHED_EVENT_DATA_SIZE /** Maximum size of scheduler events. /
#define SCHED_QUEUE_SIZE 60 /
* Maximum number of events in the scheduler queue. */
#define LORAWAN_DATERATE DR_0 /LoRaMac datarates definition, from DR_0 to DR_5/
#define LORAWAN_TX_POWER TX_POWER_5 /LoRaMac tx power definition, from TX_POWER_0 to TX_POWER_15/
#define JOINREQ_NBTRIALS 10 /**< Number of trials for the join request. */
DeviceClass_t gCurrentClass = CLASS_A; /* class definition*/
LoRaMacRegion_t g_CurrentRegion = LORAMAC_REGION_AU915; /* Region:EU868*/
lmh_confirm gCurrentConfirm = LMH_CONFIRMED_MSG; /* confirm/unconfirm packet definition*/
/**brief Structure containing LoRaWan parameters, needed for lmh_init()
static lmh_param_t lora_param_init = {LORAWAN_ADR_ON , LORAWAN_DATERATE, LORAWAN_PUBLIC_NETWORK, JOINREQ_NBTRIALS, LORAWAN_TX_POWER, LORAWAN_DUTYCYCLE_OFF};
// Foward declaration
/**brief Structure containing LoRaWan callback functions, needed for lmh_init()
static lmh_callback_t lora_callbacks = {BoardGetBatteryLevel, BoardGetUniqueId, BoardGetRandomSeed,
lorawan_rx_handler, lorawan_has_joined_handler, lorawan_confirm_class_handler};
//OTAA keys !!! ALL KEYS ARE MSB !!!
uint8_t nodeDeviceEUI[8] = {0xc7, 0x0a, 0x53, 0x8d, 0x48, 0xae, 0xb7, 0x1a};
uint8_t nodeAppEUI[8] = {0x65, 0x26, 0x5a, 0x15, 0xab, 0x2c, 0x18, 0xa6};
uint8_t nodeAppKey[16] = {0x44, 0xaf, 0x3b, 0xc3, 0xd3, 0x25, 0x6a, 0xec, 0xfd, 0x7c, 0x35, 0x78, 0xff, 0x8a, 0x4d, 0xbe};
// Private defination
#define LORAWAN_APP_DATA_BUFF_SIZE 64 /** buffer size of the data to be transmitted. /
#define LORAWAN_APP_INTERVAL 20000 /
* Defines for user timer, the application data transmission interval. 20s, value in [ms]. */
TimerEvent_t appTimer;
static uint32_t count = 0;
void setup()
pinMode(LED_BUILTIN, OUTPUT);
// Initialize LoRa chip.
lora_rak4630_init();
while(!Serial){delay(10);}
Serial.println(“=====================================”);
Serial.println(“Welcome to RAK4630 LoRaWan!!!”);
Serial.println(“Type: OTAA”);
#if defined(REGION_AS923)
Serial.println(“Region: AS923”);
#elif defined(REGION_AU915)
Serial.println(“Region: AU915”);
#elif defined(REGION_CN470)
Serial.println(“Region: CN470”);
#elif defined(REGION_CN779)
Serial.println(“Region: CN779”);
#elif defined(REGION_EU433)
Serial.println(“Region: EU433”);
#elif defined(REGION_IN865)
Serial.println(“Region: IN865”);
#elif defined(REGION_EU868)
Serial.println(“Region: EU868”);
#elif defined(REGION_KR920)
Serial.println(“Region: KR920”);
#elif defined(REGION_US915)
Serial.println(“Region: US915”);
#elif defined(REGION_US915_HYBRID)
Serial.println(“Region: US915_HYBRID”);
#else
Serial.println(“Please define a region in the compiler options.”);
#endif
uint32_t err_code;
err_code = timers_init();
if (err_code != 0)
Serial.printf(“timers_init failed - %d\n”, err_code);
// Setup the EUIs and Keys
lmh_setDevEui(nodeDeviceEUI);
lmh_setAppEui(nodeAppEUI);
lmh_setAppKey(nodeAppKey);
// Initialize LoRaWan
err_code = lmh_init(&lora_callbacks, lora_param_init,doOTAA);
if (err_code != 0)
Serial.printf(“lmh_init failed - %d\n”, err_code);
// Start Join procedure
lmh_join();
void loop()
// Handle Radio events
Radio.IrqProcess();
/**brief LoRa function for handling HasJoined event.
Serial.println(“OTAA Mode, Network Joined!”);
lmh_error_status ret = lmh_class_request(gCurrentClass);
if(ret == LMH_SUCCESS)
delay(1000);
TimerStart(&appTimer);
/**brief Function for handling LoRaWan received data from Gateway
  • param[in] app_data Pointer to rx data
    Serial.printf(“LoRa Packet received on port %d, size:%d, rssi:%d, snr:%d, data:%s\n”,
Serial.printf(“switch to class %c done\n”, “ABC”[Class]);
m_lora_app_data.buffsize = 0;
lmh_send(&m_lora_app_data, gCurrentConfirm);
//Not joined, try again later
return;
uint32_t i = 0;
m_lora_app_data.buffer[i++] = ‘H’;
m_lora_app_data.buffer[i++] = ‘e’;
m_lora_app_data.buffer[i++] = ‘l’;
m_lora_app_data.buffer[i++] = ‘o’;
m_lora_app_data.buffer[i++] = ‘!’;
m_lora_app_data.buffsize = i;
lmh_error_status error = lmh_send(&m_lora_app_data, gCurrentConfirm);
if (error == LMH_SUCCESS)
    count++;
else
    count_fail++;
/**brief Function for handling user timerout event.
Serial.println(“Sending frame now…”);
send_lora_frame();
/**brief Function for the Timer initialization details Initializes the timer module. This creates and starts application timers. */
return 0;
I will be grateful for any comments, regards.
Hello @Matias.Varas
If you are using AU915 with subband 2 (channels 8 to 15) you have to tell the library to use another subband. By default it is using subband 1 (channels 0 to 7). Short explanation
After lmh_init() and before lmh_join() add lmh_setSubBandChannels(2)
like:
if (err_code != 0)
// For some regions we might need to define the sub band the gateway is listening to
// This must be called AFTER lmh_init()
if (!lmh_setSubBandChannels(2))
   Serial.println("lmh_setSubBandChannels failed. Wrong sub band requested?");
lmh_join();
Success and working! Thanks for your help :slight_smile:
