Hi everyone,
I am new to working with LoRa module and a LoRa gateway.
I am using a LILYGO TTGO T3_v1.6.1 to send a string to the RAK7289 gateway.
The LoRa module is able to communicate with another LoRa module but is not detected by the gateway.
The code I am using is here: TTGO Module code · GitHub
Kindly help me out if there are any changes I need to do in the code to make it work.
Thank you
beegee
(Bernd Giesecke)
October 6, 2023, 11:06am
2
Welcome to the forum @Ashishgad96
I would first try to start with a simple example of the Beelan library like the Class-C-OTAA-ACK.cpp to make sure you have that part working.
Thank you very much Bernd, the library asks for appEUI and appKey, can you please let me know where I can find those 2 as I found the DevEUI on the gateway.
beegee
(Bernd Giesecke)
October 7, 2023, 5:21am
4
You can create appEUI and appKEY in the LoRaWAN server or you just invent them.
Hi Bernd, it worked, thank you!
system
(system)
Closed
October 20, 2023, 8:33am
6
