Issue:
I cant see live data of the sensor on the web page.
Setup:
Right now am just guessing between ABP and OTAA, CUSTOM CODEC AND CAYENNE, NO DIFFERENCE,
Server:
Details:
JSON up: {“stat”:{“time”:“2020-07-14 13:39:49 GMT”,“lati”:-1.33399,“long”:36.88629,“alti”:1665,“rxnb”:0,“rxok”:0,“rxfw”:0,“ackr”:100.0,“dwnb”:0,“txnb”:0}}
INFO: [up] PUSH_ACK received in 3 ms
INFO: [down] PULL_ACK received in 0 ms
INFO: Disabling GPS mode for concentrator’s counter…
INFO: host/sx1301 time offset=(1594733476s:489980µs) - drift=367µs
INFO: Enabling GPS mode for concentrator’s counter.
2020-07-14 13:40:19 GMT
[UPSTREAM]
RF packets received by concentrator: 0
CRC_OK: 0.00%, CRC_FAIL: 0.00%, NO_CRC: 0.00%
RF packets forwarded: 0 (0 bytes)
PUSH_DATA datagrams sent: 1 (157 bytes)
PUSH_DATA acknowledged: 100.00%
[DOWNSTREAM]
PULL_DATA sent: 3 (100.00% acknowledged)
PULL_RESP(onse) datagrams received: 0 (0 bytes)
RF packets sent to concentrator: 0 (0 bytes)
TX errors: 0
BEACON queued: 0
BEACON sent so far: 0
BEACON rejected: 0
[JIT]
SX1301 time (PPS): 542684541
src/jitqueue.c:448:jit_print_queue(): INFO: [jit] queue is empty
[GPS]
Valid time reference (age: 1 sec)
GPS coordinates: latitude -1.33398, longitude 36.88628, altitude 1666 m
END
JSON up: {“stat”:{“time”:“2020-07-14 13:40:19 GMT”,“lati”:-1.33398,“long”:36.88628,“alti”:1666,“rxnb”:0,“rxok”:0,“rxfw”:0,“ackr”:100.0,“dwnb”:0,“txnb”:0}}
INFO: [up] PUSH_ACK received in 0 ms
2020-07-14 13:40:49 GMT
[UPSTREAM]
[DOWNSTREAM]
TX errors: 0
BEACON queued: 0
BEACON rejected: 0
[JIT]
SX1301 time (PPS): 571779206
[GPS]
GPS coordinates: latitude -1.33397, longitude 36.88630, altitude 1671 m
END
OR
Jul 14 14:38:19 rak-gateway chirpstack-network-server[3226]: time=“2020-07-14T14:38:19+01:00” level=info msg=“gateway updated” ctx_id=56c7b278-71f9-4052-8042-9e9d6061e5fe gateway_id=b827ebfffee956bf
Jul 14 14:38:19 rak-gateway chirpstack-network-server[3226]: time=“2020-07-14T14:38:19+01:00” level=info msg=“gateway/mqtt: publishing gateway command” command=config gateway_id=b827ebfffee956bf qos=0 topic=gateway/b827ebfffee956bf/command/config
Jul 14 14:38:19 rak-gateway chirpstack-network-server[3226]: time=“2020-07-14T14:38:19+01:00” level=info msg=“finished client unary call” ctx_id=56c7b278-71f9-4052-8042-9e9d6061e5fe grpc.code=OK grpc.ctx_id=2a553025-e4eb-448a-8329-830cf015f16e grpc.duration=20.535416ms grpc.method=HandleGatewayStats grpc.service=as.ApplicationServerService span.kind=client system=grpc
Jul 14 14:38:49 rak-gateway chirpstack-network-server[3226]: time=“2020-07-14T14:38:49+01:00” level=info msg=“gateway/mqtt: gateway stats packet received” gateway_id=b827ebfffee956bf stats_id=4ae13509-2dbb-4b7e-9967-7c6d79aa187b
Jul 14 14:38:49 rak-gateway chirpstack-network-server[3226]: time=“2020-07-14T14:38:49+01:00” level=info msg=“gateway updated” ctx_id=4ae13509-2dbb-4b7e-9967-7c6d79aa187b gateway_id=b827ebfffee956bf
Jul 14 14:38:49 rak-gateway chirpstack-network-server[3226]: time=“2020-07-14T14:38:49+01:00” level=info msg=“gateway/mqtt: publishing gateway command” command=config gateway_id=b827ebfffee956bf qos=0 topic=gateway/b827ebfffee956bf/command/config
Jul 14 14:38:49 rak-gateway chirpstack-network-server[3226]: time=“2020-07-14T14:38:49+01:00” level=info msg=“finished client unary call” ctx_id=4ae13509-2dbb-4b7e-9967-7c6d79aa187b grpc.code=OK grpc.ctx_id=3d90f5ae-9b45-4144-8d95-b6015677fb69 grpc.duration=27.74625ms grpc.method=HandleGatewayStats grpc.service=as.ApplicationServerService span.kind=client system=grpc
Jul 14 14:39:19 rak-gateway chirpstack-network-server[3226]: time=“2020-07-14T14:39:19+01:00” level=info msg=“gateway/mqtt: gateway stats packet received” gateway_id=b827ebfffee956bf stats_id=c78933f8-07a5-4c75-b387-58d2af310cf3
Jul 14 14:39:19 rak-gateway chirpstack-network-server[3226]: time=“2020-07-14T14:39:19+01:00” level=info msg=“gateway updated” ctx_id=c78933f8-07a5-4c75-b387-58d2af310cf3 gateway_id=b827ebfffee956bf
Jul 14 14:39:19 rak-gateway chirpstack-network-server[3226]: time=“2020-07-14T14:39:19+01:00” level=info msg=“gateway/mqtt: publishing gateway command” command=config gateway_id=b827ebfffee956bf qos=0 topic=gateway/b827ebfffee956bf/command/config
Jul 14 14:39:19 rak-gateway chirpstack-network-server[3226]: time=“2020-07-14T14:39:19+01:00” level=info msg=“finished client unary call” ctx_id=c78933f8-07a5-4c75-b387-58d2af310cf3 grpc.code=OK grpc.ctx_id=206b4320-3fe6-4a9a-b5ce-de84757cef6b grpc.duration=19.163802ms grpc.method=HandleGatewayStats grpc.service=as.ApplicationServerService span.kind=client system=grpc
Jul 14 14:39:49 rak-gateway chirpstack-network-server[3226]: time=“2020-07-14T14:39:49+01:00” level=info msg=“gateway/mqtt: gateway stats packet received” gateway_id=b827ebfffee956bf stats_id=78625095-681a-441b-b53e-6ac4622412a4
Jul 14 14:39:49 rak-gateway chirpstack-network-server[3226]: time=“2020-07-14T14:39:49+01:00” level=info msg=“gateway updated” ctx_id=78625095-681a-441b-b53e-6ac4622412a4 gateway_id=b827ebfffee956bf
Jul 14 14:39:49 rak-gateway chirpstack-network-server[3226]: time=“2020-07-14T14:39:49+01:00” level=info msg=“gateway/mqtt: publishing gateway command” command=config gateway_id=b827ebfffee956bf qos=0 topic=gateway/b827ebfffee956bf/command/config
Jul 14 14:39:49 rak-gateway chirpstack-network-server[3226]: time=“2020-07-14T14:39:49+01:00” level=info msg=“finished client unary call” ctx_id=78625095-681a-441b-b53e-6ac4622412a4 grpc.code=OK grpc.ctx_id=af5cf52f-1efe-4424-818c-192dbc950560 grpc.duration=19.941615ms grpc.method=HandleGatewayStats grpc.service=as.ApplicationServerService span.kind=client system=grpc
Jul 14 14:40:19 rak-gateway chirpstack-network-server[3226]: time=“2020-07-14T14:40:19+01:00” level=info msg=“gateway/mqtt: gateway stats packet received” gateway_id=b827ebfffee956bf stats_id=ade1ce8c-fbfa-4f2d-8783-0d13e49c3caa
Jul 14 14:40:19 rak-gateway chirpstack-network-server[3226]: time=“2020-07-14T14:40:19+01:00” level=info msg=“gateway updated” ctx_id=ade1ce8c-fbfa-4f2d-8783-0d13e49c3caa gateway_id=b827ebfffee956bf
Jul 14 14:40:19 rak-gateway chirpstack-network-server[3226]: time=“2020-07-14T14:40:19+01:00” level=info msg=“gateway/mqtt: publishing gateway command” command=config gateway_id=b827ebfffee956bf qos=0 topic=gateway/b827ebfffee956bf/command/config
Jul 14 14:40:19 rak-gateway chirpstack-network-server[3226]: time=“2020-07-14T14:40:19+01:00” level=info msg=“finished client unary call” ctx_id=ade1ce8c-fbfa-4f2d-8783-0d13e49c3caa grpc.code=OK grpc.ctx_id=e52958ba-d7f7-4f10-a514-22f62f207385 grpc.duration=20.243438ms grpc.method=HandleGatewayStats grpc.service=as.ApplicationServerService span.kind=client system=grpc
Jul 14 14:40:49 rak-gateway chirpstack-network-server[3226]: time=“2020-07-14T14:40:49+01:00” level=info msg=“gateway/mqtt: gateway stats packet received” gateway_id=b827ebfffee956bf stats_id=89c278b7-b89c-4c47-9900-ef6823e00bb7
Jul 14 14:40:49 rak-gateway chirpstack-network-server[3226]: time=“2020-07-14T14:40:49+01:00” level=info msg=“gateway updated” ctx_id=89c278b7-b89c-4c47-9900-ef6823e00bb7 gateway_id=b827ebfffee956bf
Jul 14 14:40:49 rak-gateway chirpstack-network-server[3226]: time=“2020-07-14T14:40:49+01:00” level=info msg=“gateway/mqtt: publishing gateway command” command=config gateway_id=b827ebfffee956bf qos=0 topic=gateway/b827ebfffee956bf/command/config
Jul 14 14:40:49 rak-gateway chirpstack-network-server[3226]: time=“2020-07-14T14:40:49+01:00” level=info msg=“finished client unary call” ctx_id=89c278b7-b89c-4c47-9900-ef6823e00bb7 grpc.code=OK grpc.ctx_id=a681713a-344e-44f1-8fe4-a4020cb74883 grpc.duration=21.753125ms grpc.method=HandleGatewayStats grpc.service=as.ApplicationServerService span.kind=client system=grpc
Jul 14 14:41:19 rak-gateway chirpstack-network-server[3226]: time=“2020-07-14T14:41:19+01:00” level=info msg=“gateway/mqtt: gateway stats packet received” gateway_id=b827ebfffee956bf stats_id=fff915e7-7173-49f2-a3e7-5f02f839273f
Jul 14 14:41:19 rak-gateway chirpstack-network-server[3226]: time=“2020-07-14T14:41:19+01:00” level=info msg=“gateway updated” ctx_id=fff915e7-7173-49f2-a3e7-5f02f839273f gateway_id=b827ebfffee956bf
Jul 14 14:41:19 rak-gateway chirpstack-network-server[3226]: time=“2020-07-14T14:41:19+01:00” level=info msg=“gateway/mqtt: publishing gateway command” command=config gateway_id=b827ebfffee956bf qos=0 topic=gateway/b827ebfffee956bf/command/config
Jul 14 14:41:19 rak-gateway chirpstack-network-server[3226]: time=“2020-07-14T14:41:19+01:00” level=info msg=“finished client unary call” ctx_id=fff915e7-7173-49f2-a3e7-5f02f839273f grpc.code=OK grpc.ctx_id=661b8de5-ebbc-49ab-acad-0cd18e62af8a grpc.duration=19.57ms grpc.method=HandleGatewayStats grpc.service=as.ApplicationServerService span.kind=client system=grpc
Jul 14 14:41:49 rak-gateway chirpstack-network-server[3226]: time=“2020-07-14T14:41:49+01:00” level=info msg=“gateway/mqtt: gateway stats packet received” gateway_id=b827ebfffee956bf stats_id=2e7fc4a9-fa2c-43b0-ad51-04b65f810ee4
Jul 14 14:41:49 rak-gateway chirpstack-network-server[3226]: time=“2020-07-14T14:41:49+01:00” level=info msg=“gateway updated” ctx_id=2e7fc4a9-fa2c-43b0-ad51-04b65f810ee4 gateway_id=b827ebfffee956bf
Jul 14 14:41:49 rak-gateway chirpstack-network-server[3226]: time=“2020-07-14T14:41:49+01:00” level=info msg=“gateway/mqtt: publishing gateway command” command=config gateway_id=b827ebfffee956bf qos=0 topic=gateway/b827ebfffee956bf/command/config
Jul 14 14:41:49 rak-gateway chirpstack-network-server[3226]: time=“2020-07-14T14:41:49+01:00” level=info msg=“finished client unary call” ctx_id=2e7fc4a9-fa2c-43b0-ad51-04b65f810ee4 grpc.code=OK grpc.ctx_id=69ee690c-6590-4103-a4d4-730675afec17 grpc.duration=20.673125ms grpc.method=HandleGatewayStats grpc.service=as.ApplicationServerService span.kind=client system=grpc
I dont know what any of those mean, am using EU-868Mhz, server address 127.0.0.1.
Is there a clear procedure on choosing apb or otaa? applying app keys, tls certificates?, as you can see am new to this, i have no idea, i thot its going to be a plug and play kinda situation
