Connection issue with aurdino ide
HI everyone, I am having trouble uploading my code with RAK4630 using Arduino IDE when checking the error code it led to uploading the bootloader file using meshtastic web flasher website but why trying to paste the UF2 file the DFU mode automatically closes and the process is interrupted. I need to know is there any other way to upload the file or what is the mistake that i am currently doing i have attached the Arduino error code and the DFU error below.
Arduino error:
Sketch uses 307416 bytes (55%) of program storage space. Maximum is 557056 bytes.
Global variables use 76688 bytes (37%) of dynamic memory, leaving 129760 bytes for local variables. Maximum is 206448 bytes.
2026-04-22 11:18:45,581 Using board at serial port: COM18
2026-04-22 11:18:45,584 Sending Application image.
2026-04-22 11:18:49,151 No trigger interface found for device with serial number: 494CB2B70B34AA75, Product ID: 0x0029 and Vendor ID: 0x239A
2026-04-22 11:18:49,151 Serial: Waiting 500 ms for device to enter bootloader 1/10 time
2026-04-22 11:18:49,666 Serial: Waiting 500 ms for device to enter bootloader 2/10 time
2026-04-22 11:18:50,179 Serial: Waiting 500 ms for device to enter bootloader 3/10 time
2026-04-22 11:18:50,694 Serial: Waiting 500 ms for device to enter bootloader 4/10 time
2026-04-22 11:18:51,204 Serial: Waiting 500 ms for device to enter bootloader 5/10 time
2026-04-22 11:18:51,712 Serial: Waiting 500 ms for device to enter bootloader 6/10 time
2026-04-22 11:18:52,222 Serial: Waiting 500 ms for device to enter bootloader 7/10 time
2026-04-22 11:18:52,734 Serial: Waiting 500 ms for device to enter bootloader 8/10 time
2026-04-22 11:18:53,245 Serial: Waiting 500 ms for device to enter bootloader 9/10 time
2026-04-22 11:18:53,757 Serial: Waiting 500 ms for device to enter bootloader 10/10 time
2026-04-22 11:18:54,268 Serial: Device is either not in bootloader mode, or using an unsupported bootloader.
2026-04-22 11:18:55,286 Serial: No ping response
2026-04-22 11:18:56,292 Serial: No ping response
2026-04-22 11:18:57,299 Serial: No ping response
2026-04-22 11:18:58,306 Serial: No ping response
2026-04-22 11:18:59,316 Serial: No ping response
2026-04-22 11:19:00,326 Serial: No ping response
2026-04-22 11:19:01,332 Serial: No ping response
2026-04-22 11:19:02,340 Serial: No ping response
2026-04-22 11:19:03,348 Serial: No ping response
2026-04-22 11:19:04,356 Serial: No ping response
2026-04-22 11:19:05,362 Serial: No ping response
2026-04-22 11:19:06,371 Serial: No ping response
2026-04-22 11:19:07,381 Serial: No ping response
2026-04-22 11:19:08,391 Serial: No ping response
2026-04-22 11:19:09,399 Serial: No ping response
2026-04-22 11:19:10,405 Serial: No ping response
2026-04-22 11:19:11,415 Serial: No ping response
2026-04-22 11:19:12,423 Serial: No ping response
2026-04-22 11:19:13,431 Serial: No ping response
2026-04-22 11:19:14,440 Serial: No ping response
2026-04-22 11:19:15,447 Serial: No ping response
2026-04-22 11:19:16,462 Serial: No ping response
2026-04-22 11:19:17,467 Serial: No ping response
2026-04-22 11:19:18,471 Serial: No ping response
2026-04-22 11:19:19,484 Serial: No ping response
2026-04-22 11:19:20,490 Serial: No ping response
2026-04-22 11:19:21,500 Serial: No ping response
2026-04-22 11:19:22,509 Serial: No ping response
2026-04-22 11:19:23,509 Serial: No ping response
2026-04-22 11:19:24,517 Serial: No ping response
File “nordicsemi_main_.py”, line 1545, in
File “click\core.py”, line 1137, in call
File “click\core.py”, line 1062, in main
File “click\core.py”, line 1668, in invoke
File “click\core.py”, line 1404, in invoke
File “click\core.py”, line 763, in invoke
File “nordicsemi_main_.py”, line 1063, in serial
File “nordicsemi_main_.py”, line 980, in do_serial
File “nordicsemi\dfu\dfu.py”, line 127, in dfu_send_images
File “nordicsemi\dfu\dfu.py”, line 88, in _dfu_send_image
File “nordicsemi\dfu\dfu_transport_serial.py”, line 214, in open
pc_ble_driver_py.exceptions.NordicSemiException: No ping response after opening COM port
[17428] Failed to execute script ‘main’ due to unhandled exception!
CompletedProcess(args=[‘C:\Users\admin\AppData\Local\Arduino15\packages\rak_rui\tools\pc-nrfutil\v6.1.7/nrfutil’, ‘-v’, ‘-v’, ‘-v’, ‘dfu’, ‘serial’, ‘–package’, ‘C:\Users\admin\AppData\Local\arduino\sketches\825AC44DCC0911CE239F2823016A22AE/sketch_apr22a.ino.zip’, ‘-p’, ‘COM18’, ‘-b’, ‘115200’], returncode=1)
DFU error:
Welcome to RAK forum @naveen
The code is compiling ok but I have suspicion that you are using RAK4630 RUI3 and not the Arduino BSP that is compatible with Meshtastic.
To help you further,
  1. Can you please share the exact hardware you are using? If you got it form our webstore, can you share the specific SKU?
  2. What guide did you follow when you upload the Arduino code?
  3. Will you be able to share what is in the Arduino code? Can you test first basic LED blinking?
  4. What is the hardware you are using? Is it direct from RAK or a custom design?
currently i am using RAK4630 with the RAK19001_VB board that was purchased directly.
As of for the software i am using Arduino IDE2.3.4 which i have been using for my previous projects for esp32 I have added the required library and the json links to it.
I tried uploading the led blink examples from the library.
Below is the refence link that i have used
RAK4630 WisDuo LoRaWAN+BLE Quick Start Guide | Setup & Configuration
I have mentioned the details that you have asked for below
I tried uploading the le blink examples inside the library.
and below is the link that i used as an reference for setup
I am currently using arduino ide 2.3.4 which I have been using for my other projects for ESP32.
I am currently using the RAK4630 module along with RAK19001_VB that we bought directly frim
I have downloaded the library and the JSON link correctly. I tried uploading the led example from the library.
this is the refrence that i have used.
Hi @naveen ,
It would be best if you can share the specific SKU when you order so I can know what RAK4630 you have.
Anyways, if you connect it to PC and double click the reset button on the base board, does it show a RAK4631 Drive?
If RAK4631 Drive doesn’t show, if you connect to it and send AT or AT+VER=? do you get any replies?
Hi @carlrowan
this is the one but we bought it from a third-party vendor (TAOBAO).
Yes the drive is visible after reset but when copying the UF2 file it gets closed automatically.
whereas for the command there is no response for both 9600 was the baudrate while sending the command
Hi @naveen ,
If it is detected as drive, then the bootloader seems to be ok.
However, if you drag the Meshtastic FW and it keeps failing, there might be a problemin the module already. You can still try to change USB, test on different PC or reupload the bootloader using Jlink. These methods usually fix the issue related to that.
Hi @carlrowan
I tried uploading the bootloader using the command prompt method according to the rak4631/quickstart/#updating-the-bootloader link and it was successful but still while uploading the code the Arduino is still giving me the error .
Hi @naveen ,
I am a bit confused on the steps you are taking. What is the end objective you need to have? Is it uploading Meshtastic FW? Custom FW?
Updating bootloader is only needed if you are changing FW type if RUI3 or Arduino BSP. Or if the bootloader is corrupted.
hi @carlrowan,
I wanted to upload example code into the rak module it wasnt uploading so i wanted to upload the bootloader file. but i was able to upload the file and the proble is resolved and i have moved on with my project thanks for the support. Right now, I am dealing with a different issue while scanning for ibeacons i am able to detect and retreive the uuiid and transmit them using lora but when i try to calculate the distance using rssi value the value measured keeps on fluctuating even if it is near the rak module.If you have any idea regarding this can you guide me.
