I CAN’T CONNECT THE WiFi and BLE Espressif ESP32-WROVER RAK11200 WITH THE ARDUINO CLOUD
YES YOU CAN?
HOW CAN I DO IT?
ANY HELP TUTORIAL, THANK YOU!
Welcome to the forum @Gustavo_20
What exacty is your problem?
For generic usage of the RAK11200, did you try our Quickstart Guide?
Or did you have a look into our Communication Examples?
For Arduino Cloud, did you follow their Getting Started with the Arduino Cloud?
EL PROBLEMA ES
SUBIR DATOS DE SENSORES DEL IOT CON WiFi y BLE Espressif ESP32-WROVER
RAK11200 A LA NUVE DE ARDUINO .
SI ME CARGA PERO AL MODIFICAR EL CODIGO PARA OBTENER DATOS DE LOS SENSORES ME SURGE ERROR
Can you give a little bit more details.
IT LOADS ME BUT WHEN I MODIFY THE CODE TO OBTAIN DATA FROM THE SENSORS, I GET AN ERROR
This doesn’t really help.
What code are you using, what sensors are you talking about, what error do you get?
Why can’t I get data from the sensor?
It gives me an error when reading the data in the arduino cloud and I cannot visualize myself on the Dashboards
arduino cloud sensor code
Why does it show an error when reading the data?
My goal in visualizing the data in the Dashboards the arduino IDE
Did you try the example code for the RAK1901? RAK1901_Temperature_Humidity_SHTC3
Does it read sensor values and shows them in the Serial Terminal?
Saying “it shows an error” does not help at all to find the problem.
if i tried the sensor code…
On arduino cloud serial monitor does not read sensor data
Why doesn’t it read me the sensor data?
This is not the example code I asked you to try.
I do not know what this Arduino Cloud example code is doing.
Please try our example code first to make sure the sensor is working.
I cannot help you, you are not doing what I ask you to do.
Try the simple example code I told you to use first. You will get this output if the sensor is working:
I have no idea what code you are using and what it does. If this code is provided by Arduino Cloud then ask them why their code is not working.
OK. Solucionado el problema.Gracias
